Awesomatix EP Touring Car (A700 Shaft Drive)
#9526
48/74 will be good gearing for Ripon for sure , ill keep that one in mind.trying to get down past 2.90 for the back stretch at Speedworld i max out about half way through it. Im going to try 51t 64p spur and dremmell down a touch, jut wondering if theres a way to " hump " that rear upper to clear without losing strength.
#9527
#9529
any mods to get a larger spur gear than 50t/64p on the A700 without removing the top plate? and... if removing the top plate run which bottom chassis stiffener on the CF chassis? im topped out gear wise @ 50/72 and the motor mount is all the way to its stops to get decent gear mesh. thanks for any input.
running 25.5 in VTA if that matters.
The winner of TITC 2017 in non-bust class has used on his A700 the 52T pinion with 70T spur ( FDR 2,8 ).
#9530
HAHA nope. 2016 Speedworld Cup
Race Results
Just been waiting for you to get fast enough to run it again, still waiting
And, yep, I don't run a topdeck on my A700
Race Results
#9531
#9534
Race Results
Race Results
Ill be at SWR for round seven series on Sept 17th i think... drop a pic of your ride so i know who to bug LoL
#9535
Any brand 6x3mm round shims of the desirable thickness.
Awesomatix offers 0,5mm, 1mm, 1,75mm thickness shims.
SH0.5 - 6x3x0.5mm Spacer (Silver) x 10 ? AWESOMATIX
SH1.0 - 6x3x1.0mm Spacer (Gray) x 10 ? AWESOMATIX
http://shop.awesomatix.com/index.php?productID=771
#9537
did awesomatix mae the rear body mount plate in graphite or was that just on the prototypes ?
#9538
#9540
