SMC 4000/25C/3.7V single cell Hardcase pack.
#121
Guest
hey danny
hello danny, i am going to get a crc genx10. will the single cell 3.7 fit in that car??if it will i want 2 of them !!
#124
What/which "red wire" are you guys removing from the esc? Why?
Also which receiver packs do you folks using? Brand name part#
#125
The red wire on the white,black,red wires on the harness that plugs into the receiver. I removed mine because the esc would try to run the motor off of the receiver pack with it plugged in. I used a maxamps micro t battery for my receiver pack.
#126
You shouldn't need to remove any wires from the newer speed controls. Just use a switch on the receiver pack or booster and don't use the switch on the speedo. I tape over the switch so that turnmarshalls don't use the wrong switch.
#127
But it still pulls power from the receiver pack to power the motor regardless if the regular battery is plugged in or not. There is a noticeable rpm difference when the receiver pack is plugged in and all esc wires are are still going to the receiver pack.
#130
So with the booster curcuit novak will be releasing, will it eliminate the dumping feeling for existing escs? or will it just be an alternative to a receiver pack?
#131
The Booster circuit will eliminate the reciever pack. Novak tells me that it will get rid of the dumping feeling with there speed controls due to the way they are made. They told me that you turn on the booster circuit and keep the speed control switch off. I would think that a reciever would do the same thing with there speed control but that needs to be tested. I guess all this will need to be tested.
#132
#134
I got to run this in my CRC Gen-X tonight. I'm hooked.
Here's my setup:
LRP Sphere comp (esc was switched off)
Vector 10.5 brushless motor geared 100/35
Futaba 603fs receiver
Losi 180mah Micro-t lipo as receiver pack with voltage regulator.
I had to remove the battery positioning pieces in the Gen-X. I taped it in place and used the battery hold down o-ring. There was plenty of room under the shock.
I did not clip the red wire from the esc lead to the reciever. I tried cutting it and got no power to the motor at all.
I added 1.25 oz of weight to the battery to get the car to 794g.
The track is 35 x 100 ft with 7ft lanes high bite carpet. Medium layout.
We had 4 racers: 1 stock brushed, 1 19t brushed geared ~75/35 with epa down to ~85%, myself, and one AE sponsored guy 10.5 brushless geared to the moon.
The sponsored guy was turning low 9 sec laps. My best lap was 11.4 and the 19t brushed best lap was 11.0.
We were running 6 min races. I did not notice any drop off/dumping feeling. when recharging, I was putting in ~800-1000 mah back in.
Overall, I feel that with a little more gearing I can compete with any of the pretty fast guys running 19t/10.5. I don't think I could beat the sponsored guy if he was running stock with 2 cell nimh while blindfolded.
Anyway, enough said, I ain't going back.
Regards,
Carter
Here's my setup:
Regards,
Carter
Last edited by darcydawg; 11-25-2008 at 06:18 AM. Reason: added bit about esc being switched off
