LRP Vector x12 Brushless Motors >
Old 02-24-2012, 08:55 AM
  #586
Originally Posted by Manson
Under 4.5 turns it s totaly useless. If you want more topspeed just set your ESC
Gearing and turbo boost is more of a factor for topspeed I agree. But I am looking for pure acceleration actually. I want to push it to the limit just before wheelspin. Any pointers?
EvetsFidrat is offline
Old 02-29-2012, 07:26 AM
  #587
LIUK82's Avatar
Unhappy PROBLEM WITH X12 5T
HELLO GUYS TODAY I HAVE OPENED TO CLEAN IT AND OIL BEARINGS LRP X12 5T
I DON'T REMEMBER THE POSITION OF 2 + OF 2 SHIM WHITE AND BLACK O-RING
THE INSTRUCTION MANUAL ON SITE SAY
PUT FIRST IN THE FRONT OF MOTOR ON BEARING THE O-RING AND AFTER THE SHIM BUT SHOW ONLY ONE WHITE SHIM
DON'T SHOW 2 SHIM :-(
YOU NEVER OPEN THIS MOTOR? HELP ME THANK! :-(
LIUK82 is offline
Old 02-29-2012, 07:51 AM
  #588
Any recommendation for gearing a x12 13.5 for boosted TC?
I run at a track with a 35m straight along with a Tekin RS-Pro.
Also, what motor temp am I aiming to keep the motor under?
iwkyb is offline
Old 02-29-2012, 08:02 AM
  #589
Pro10noob's Avatar
How is the rest of the track??
tech?flowing?
We need a bit more from you.
Don't get the X12 above 65 degrees and use the stock timing insert.
Starting point for the gearing is 7.5 to 8 and work your way from there.
Temp motor every 3 minutes and if cold, gear up a bit.
regards Roy
Pro10noob is offline
Old 02-29-2012, 04:51 PM
  #590
tech?flowing?
regards Roy
I use the 4 dot insert with the lowest mechanical timing.
I heard from others that LRP usually runs hotter than other motors and can be pushed up to 100 degrees? or is that due to incorrect settings?
I am currently running 35 boost + 10 turbo on FDR of 6.5 - temp after 6 minutes at about 75 degrees
cheers
iwkyb is offline
Old 02-29-2012, 05:04 PM
  #591
Craig W's Avatar
try 7.4 to 8 with a guess
Craig W is offline
Old 02-29-2012, 05:49 PM
  #592
Losiho's Avatar
cheers
I was running 21.5 on sunday at TFTR. Was running 46 degrees timing on the motor, 5.1 FDR, SSX Stock Spec setting 3,0,10,0 and I was thermalling after 5 laps. Temp gun readings on the motor were well over 90 degrees C.
Yes it was too hot for those settings
Losiho is offline
Old 02-29-2012, 06:23 PM
  #593
Wow, thats a lot of timing
iwkyb is offline
Old 02-29-2012, 07:26 PM
  #594
Losiho's Avatar
Yes. It was a good lesson. Needless to say, I've turned down the timing and changed the gearing since Sunday
Losiho is offline
Old 03-04-2012, 09:22 AM
  #595
littlevette's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Buckaroo
When I need to do something like that, I use electronic contact cleaner. Red spray can from the automotive section of WallyWorld.
that was my initial thought when it first came up on what spray to use.
littlevette is offline
Old 03-10-2012, 11:19 PM
  #596
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Hello guys I have a 17.5 X12 motor, Whats the best method for cleaning a engine?
entitymugenmtx is offline
Old 03-11-2012, 06:10 AM
  #597
Buckaroo's Avatar
Take it apart and blow it down with compressed air, then detail with a dry toothbrush to get any stubborn dirt, clean and re-lube the bearings, then reassemble. Start to finish, 10 minutes.
The coating on the motor windings isn't always epoxy, sometimes it's lacquer based, and some motor sprays and carb or brake cleaners will eat or degrade that coating on the windings, so be careful what you spray in a motor. I've seen bad things happen to good motors with guys spraying stuff that was safe for brushed motors into the current crop of brushless ones.
I know for sure that electrical contact cleaner (red spray can from autozone, pep boys, wal mart, etc) is safe. If you must spray any liquid into a motor, use sparingly! Then clean more often!
Buckaroo is offline
Old 03-15-2012, 02:23 AM
  #598
daverobbo5's Avatar
Trader Rating: 45 (100%+)
Default 12.45mm std rotor versus 12.5mm
I'm running the X12 17.5 in a Hotbodies D4. i've kinda found the sweet spot with the gearing running a regular 60 degrees C(about 130F) previous geraing at about 5.6FDR was above 70 degrees the but X12 really losses punch for off road jumping.
Another racer told me the 12.5mm rotor is worth getting to 'tune it up' like the HT rotors for Tekin and Trinity D3.
in this forum recers say that only the 13mm rotor is worth it but it's not legal
http://www.lrp.cc/forum/viewtopic.php?f=4&t=7592
in this ad it says the motor comes with a 12.5mm and then it says 12.45mm
http://www.lrp.cc/en/products/electr...-175t/details/
is it worth buying the Part. no.: 50633X12 12.5mm Sintered Rotor for 0.05 of a mm I would think it would not be worth it.
The 0.2mm rotor for the Trinity D3 does make a difference apparently
any thoughts? thanks
daverobbo5 is offline
Old 03-15-2012, 09:59 PM
  #599
daverobbo5's Avatar
is this any indication of weather anyone still runs this motor?
Old 03-17-2012, 06:31 PM
  #600
daverobbo5's Avatar
just wanted to put this out there agian as i have a chance to buy a 12.5mm rotor to replace the 12.45mm.thanks
