XRAY T2’009
Old 02-03-2009, 02:27 PM
  #481
Johnny Wishbone's Avatar
A little of both. From what I've experienced the back is unpredictable loose causing a oversteer issue. The only problem is with the 2 different width wheels its going to be a little bit of give and take to get it close, then tune from there. Bad part is that it will work for VTA but it will pretty much suck for TC rubber, setup wise.
Johnny Wishbone is offline
Old 02-03-2009, 03:36 PM
  #482
Skiddins's Avatar
Originally Posted by pcar951
Yo Skiddins. You never did tell me why you run so much droop in your setup. Care to share??
I run the droop measured on a droop guage as opposed to droop over ride height which most guys on here use.
The actual values have come from the faster guys I race with sometimes. But having less droop seems to make the car too 'on edge' for me. I race mainly on low grip asphalt.
Skiddins
Skiddins is offline
Old 02-03-2009, 03:52 PM
  #483
That's intersting to hear your thoughts on a VTA set-up. I've struggled with my 008 in VTA and finally have it pretty close by doing something similar.
Using Paul L's Trackside set-up with the exception of adding 2mm more of front track width to help account for the offset VTA wheel deal. 1mm more on the arm shims and a 1mm wheel shim. There are no shims in the rear other than for toe on his set-up already.
I've had the best luck setting it up with the regular touring car wheels to get the ride height and then switching to the VTA wheels and letting the ride height go up to whatever. Tried both and think I would need to move pivot points to get the lower ride height to work with the tall VTA tires
I've ran the spool and the one-way. It carries noticably more speed through the infield with the one-way and for me is easier to drive. Could this be because of the limited 21.5 motor? I tried to stick it out with the spool and may go back to it sometime, but it just really binds up in the tight infield. Maybe the upgrade shafts will help?
I came into this deal with no touring car experience what so ever. This thread and the 008 thread have with out a doubt helped me ten fold over any practice or experimentation I could have done in this amount of time.
Thanks guys...
Stetler17 is offline
Old 02-03-2009, 09:51 PM
  #484
You could try the 50mm drive shafts up front.
Old 02-04-2009, 02:50 PM
  #485
fullout's Avatar
I'm looking to pick up a 009, who has them instock at the best price?
fullout is offline
Old 02-04-2009, 03:42 PM
  #486
Default Very loose rear end / oversteer
I'm using a brand new 009 set up as per manual, i race on a dusty concrete track. Im using cs22 and tried sorex 20, the motor is a Novak 13.5. The car is very fast compared to my old FK05 (might be some of the problem) Whats happening is when i exit a tight corner the back end just lets go under acceleration it goes into the corner fine. I had a similar problem on the FK05 and loosening the rear diff solved that. Anyone got a tips to try as a starting point. Its so bad i was only getting 14 laps when i can get 20 with the old car but the 009 is a lot faster on the straight.
BILKO1 is offline
Old 02-04-2009, 04:12 PM
  #487
Trader Rating: 23 (100%+)
We're all living the same dream it seems! Rear traction issues are common with the 009, read posts starting back a couple of weeks. In our area we're running rubber tire on carpet right now, I can't imagine dusty concrete! I'm sure others have suggestions but, my initial changes would be;
- remove or reduce the rear sway bar
- lay down the rear shocks or reduce spring rate
- increase front droop (since it's on power)
Hope this helps
pcar951 is offline
Old 02-04-2009, 04:13 PM
  #488
dawgmeat's Avatar
Does the ECS drive shafts come with the kit? thanks in advance
dawgmeat is offline
Old 02-04-2009, 04:22 PM
  #489
KHoff7's Avatar
no
KHoff7 is offline
Old 02-04-2009, 05:25 PM
  #490
JasonC's Avatar
Trader Rating: 120 (100%+)
US or UK version ?
best price i have found so far is
http://rc-mushroom.com/product_info....ducts_id=16138
but shipping is not cheap
if your looking for the US / foam spec below have them in stock
http://www.nexusracing.com/ and
http://www.ampdraw.com/ and http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
JasonC is offline
Old 02-04-2009, 06:06 PM
  #491
Skiddins's Avatar
Get the thinner optional asphalt topdeck.
Skiddins
Skiddins is offline
Old 02-04-2009, 08:39 PM
  #492
fullout's Avatar
sorry. i should of specified the rubber edition.
fullout is offline
Old 02-05-2009, 08:12 AM
  #493
Skiddins
I'm running the eu rubber version theres a optional top deck? part number please as i can't find the bugger anywhere
BILKO1 is offline
Old 02-05-2009, 08:59 AM
  #494
301185
pcar951 is offline
Old 02-05-2009, 12:51 PM
  #495
One last question on spool V. oneway fixed......Wouldnt the oneway be so much faster steerin wise and still give you the rip out of the corner?
NUCRPTRACER is offline
