XRAY T2’009
Old 06-12-2009, 03:53 AM
  #1231
noline's Avatar
Does anyone know where on line I can get some orange anodized Xray T2 09' parts? I usually get my xray stuff from Nexus Racing but there out of stock.
noline is offline
Old 06-12-2009, 06:10 AM
  #1232
rcterp's Avatar
Trader Rating: 35 (100%+)
Stormer has a decent selection if Nexus is a no go.
rcterp is offline
Old 06-12-2009, 06:14 AM
  #1233
You also can check ashfordhobby.com
SRW141 is offline
Old 06-12-2009, 07:13 AM
  #1234
I think they got a shipment today. I just made an order because they received the servo mounts I wanted. Looks like all orange is in stock other than the bulkheads, but I'm not sure if they are getting those because they have been showing "coming soon" for a while.
JHIH is offline
  #1235
LowBoost's Avatar
Trader Rating: 63 (100%+)
Has anyone tried a Tekin RX8 with a 3.5 or 3.0 motor?
Any comments?
LowBoost is offline
Old 06-12-2009, 10:21 PM
  #1236
J.Filipow's Avatar
Trader Rating: 15 (100%+)
This is for my buddy Drew Ellis!
http://www.youtube.com/watch?v=Zx1eDmuYQg8&feature=fvw
J.Filipow is offline
Old 06-13-2009, 01:22 AM
  #1237
Korey Harbke's Avatar
do do do the system is down do do do
Korey Harbke is offline
Old 06-13-2009, 01:10 PM
  #1238
Can anyone tell me if this belt:1x XRA305442 - Xray T1 High performance Rear Belt, has another part # that is used on another car.
I need this belt to do a mod. for my Tamiya 415.
Thank you guy for any help.
Cheerz
Obsidian is offline
Old 06-13-2009, 01:40 PM
  #1239
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Cheerz
i believe the xray belt is 3mm x 180mm ( 60t ) so you can use the folliwing belts, the shumacher rear belt part # U2721 and you can also use the HPI belt for the RS4 part # A848 or HPI A732 but its a 5.5 mm rear belt so its pretty wide.
Marcos.J is offline
Old 06-14-2009, 12:32 PM
  #1240
Thank you very much Marcos. I appreciate all your help.
Cheerz
Obsidian is offline
Old 06-14-2009, 06:12 PM
  #1241
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
any1 know if those lipo plates slip into a 008/009 (not the 'crooked' 1 from stormer hobbies)? i've just learned that i want to run nats (which is in the backyard this yr), not allowed to have lead on the battery. i ordered the 'lipo decks' for my 008 from xray to give the proper clearance as i told. but i'm goin to need a whole lotta weight to make 1500. right now less speedo, main wiring, and paint....i'm only 1285!!! and thats with 48g of lead down center spine under belt, 28g out back on either side of rear pod and a lil 7g in the nose. heard xray was coming out with a weight setup for the car but havent seen it f/s anywhere or what it costs. between this issue and debate over rules for 12 scale (1s vs 4cell, motors, weight etc)....this isnt lookin for good for myself and surely others.
perhaps 1 of the other plates they have listed for other chassis will work if the lipo decks are added?
help!
R
UltegraSTI is offline
Old 06-14-2009, 11:19 PM
  #1242
Trader Rating: 88 (100%+)
help!
R
the PPD plate fits perfect in a 008/009..
http://www.nexusracing.com/product_i...oducts_id=2584
joey is offline
Old 06-14-2009, 11:55 PM
  #1243
Skitee's Avatar
Cheerz
The T2, T2'007 belt will also work
Skitee is offline
Old 06-16-2009, 12:25 AM
  #1244
Has any one played with the +2mm roll centre mounts yet?
I put them on for a couple of runs at our indoor high traction track the other week, and the car had heaps of grip, but was just too unresponsive, maybe outdoors they will be better. But then i started to compare the 009 to my 416, and the 416 has the arm mounts around 1mm higher than the xray mid, and the top links are much longer, about 1mm longer than even the +2 mounts.
Has anyone tried to run the high arm mounts, and the +2 links? This might give the overall grip and responsiveness that the 416 has.
Any thoughts?
Besercoe is offline
Old 06-16-2009, 05:57 AM
  #1245
Skiddins's Avatar
If you measure closely, the front holes for the upper links on the 009 (I'm talking about the shock towers) are actually higher than those at the rear.
If you put the links in the 'same holes' front and rear, the fronts will actually be higher.
I can't remember the exact number but it might be as much as 2mm.
Skiddins
Skiddins is offline
