Tamiya TB-02
#106
Originally posted by tamiyarcracer
The tires are a kit slick, atleast the ones in my skyline are.
Izzy I have pictures of mine, but it is with the blue conversion kit on it.
As for handling, out of the box it had a little push with the kit set-up, the tracktion was low on the surface I ran on, it was at Burien RC. The only change was a set of A tires soft inserts in the front, and hards in the rear. The changes that were mad was, lengthening the upper arms (camber links) and shock oil. The car was pretty good with those changes. I then went to sway bars, yellow all the way around and it got really pushy again.
#107
I did post them, I thought it was here.
maybe on the evo thread
#108
It was fun building it. I used a 55/22 on a reedy rage stock motor. I think that was 6.5 ratio. I t has skinny hex adaptors so I replaced it with some tl01 regular sized thickness to widen the stance. Has a thin spacer for the front wheels too. First impression was it was smooth and very responsive. I had just sold a really nice ta04r and I like this one better. I ran it stock with a set of threaded shocks I had from my ta04r. Lots of potential and comes with ball diff,alloy propeler shaft and pretty much my ta04 arms and carriers should fit. Not sure about universals though. Great job Tamiya. For less than $150 you can't go wrong.
#110
Then I guess the ta04's universal is tad short then. Anyone with suspension setup for these cars?
#112
Thanks to everyone that helped me with my other questions.
I have another question, does any one know if i can get a 4.2 to 4.35 final drive ratio. I have worked out I would need a 30t pinon and 49t spur gear, would this be possible.
#113
Supersonic, the first question is, can you get a 49t spur?
#115
I have raced the TB02 against a TRF 414M2 out of the box it was good against the M2. ( I thought I typed that a few days ago, I know it was only 10days at the most) Difuser was driving the M2. I have not run a one way yet. I would guess it will have the same issues. But maybe not. the cahssis is tied together differently. and it might be stiffer from front to rear than a plate car, but it is about as soft as the evo 3 with a2.5mm lower deck torsionaly.?.?.
Difuser had a night of practice with the car. I sat it down on the track on Sunday morning. I had a 5.0 gear ration. he had a 5.3 as for gearing the two I ran were a 5.0 (27/52) and a 5.2 (26/52), remember a 5.7 might be the next step, but there might be something in the middle with the 52 tooth spur. just need to check it when you build it.
#116
Here are some pics
#117
More
#118
another
#119
And last but not least
#120
tamiyarcracer, thats what i was thinking to. Does anyone know of a 54t spur gear in normal 48 pitch.
