TAMIYA F103 RM
Old 05-10-2009, 07:45 AM
  #1966
bakaguyjean's Avatar
Originally Posted by evanwest94
Just get a new Tamiya part as the 3Racing ones break twice as fast as the Tamiya part and a used one might be bent all ready. Both of the wheel mounts on the F103GT take alot of hits.
bakaguyjean is offline
Old 05-10-2009, 06:46 PM
  #1967
Arahawak's Avatar
Trader Rating: 32 (100%+)
Not sure if this was asked before.. but how to raise the front ride height of the F1? I know the rear has spacers.. but the front?
If i add shims, it only lower the car..
Arahawak is offline
Old 05-10-2009, 09:58 PM
  #1968
mild seven's Avatar
Trader Rating: 63 (100%+)
There is no real way of raising the front ride height.
mild seven is offline
Old 05-10-2009, 10:24 PM
  #1969
Arahawak's Avatar
I guess so too.. was thinking if you guys have other innovative way besides using bigger tires.
Arahawak is offline
Old 05-11-2009, 02:14 AM
  #1970
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
I think I saw step by step for it on these threads somewhere before but I've done this fix: Disassembled the steering knuckle/front kingpin assembly; I shaved off about 2mm from the bottom of the steering knuckle, reassembled it by placing a 2mm spacer above knuckle then placed the front kingpin spring above it, used a setscrew to fix the kingpin in place (setscrew in inner portion of steering knuckle). These are then sandwiched between the upper and lower front A arms. That's it! You can adjust for proper spacing and suspension travel by adjusting kingpin/setscrew. When your tire diameter is big, place 2mm spacer at bottom of steering knuckle for kit settings. For small diameter tires, put the 2mm spacer above knuckle for extra 2mm ride height. Added bonus of this is that you need not worry about your e clips on the kingpins anymore. You also won't lose any front springs in the event said e clip falls off.
Big Daddy Cool is offline
Old 05-11-2009, 02:16 AM
  #1971
Arahawak's Avatar
This is TAC legal i suppose?
Arahawak is offline
Old 05-11-2009, 02:21 AM
  #1972
I used Tamiya 2mm blue aluminum spacers so there aren't any non-tamiya parts. Shaving off sections from parts doesn't seem to be illegal... Better check with your tamiya organizers though.
Old 05-11-2009, 03:20 AM
  #1973
Arahawak's Avatar
Thanks! i try that..
Arahawak is offline
Old 05-11-2009, 03:28 AM
  #1974
GREGORY!'s Avatar
Default first time in f1 class!
hi boys.i want to get in this wonderful class.
it has been past 10 years from my first electric kit.i kyosho outlaw truck !
for now i am in 1/10 and 1/8 gp class.
now i think its time to buy a clean,quiet,fast and cheap car!
i think that a f1 electric is the way to go.
now!
i want to help me choose one tamiya f1 kit.i want to know
which model i must buy,
what parts i must have as spares[what breaks easy]
which option i must buy.
what tyres is better for outdoor use.
and so on.
everything i must know!!
i have seen in this forum that there are a many guys with very good knowledge here in these cars.so please help me in this!
thanks!
GREGORY! is offline
Old 05-11-2009, 05:42 AM
  #1975
grouch's Avatar
This might be a dumb question but I gotta know. I want to keep my car TCS legal and need to get a battery for it. The Tamiya website list batteries that are legal but I am having a hard time finding where to buy them. How do I know if a certain Trinity, Duratrax or Orion battery conforms to the list of approved cells.
Sanyo NI-CD 2400, Sanyo NI-MH HV 3000, 3300 & 3600
Panasonic 3000 Ultra Metal Hydride, Panasonic 3000 Stock Metal Hydride
GP (Gold Peak) 3300 & 3700, 4300, 4600
Intellect Batteries 3600, 3800 and LRP 3700, 4200, 4600
EPIC 3800, EP 4600.
Thanks all!
grouch is offline
Old 05-11-2009, 07:32 PM
  #1976
Arahawak's Avatar
now!
and so on.
thanks!
If you still can get your hands on a 15th Anniversary F103, that's your best bet. It comes with all the options.
Otherwise go for a F103RM and hopped it up. F103RM stock configuration is pretty good to go.
Tyres - depends on your track. The Tamiyas ones are good enough. There are other brands out there available. Unless you are running TCS, you check with your organisers if there is a restriction.
The F103 is pretty tough.. haven really broke anything even after a few hard knocks. so stocking up on parts not really necessary unless you are pretty far from your LHS, otherwise i say get a spare arm, thrust bearings, the diff balls and lotsa of tyres.
Arahawak is offline
Old 05-11-2009, 07:33 PM
  #1977
Arahawak's Avatar
EPIC 3800, EP 4600.
Thanks all!
Best way is to check with your local organiser..
In our local TCS, we are running open Nimh and NiCd batteries. Lipos are not allowed.
Arahawak is offline
Old 05-11-2009, 08:20 PM
  #1978
fatboy's Avatar
Yo, I thought you sold off your car
fatboy is offline
Old 05-11-2009, 08:47 PM
  #1979
Arahawak's Avatar
I got a 15th Anniversary
Arahawak is offline
Old 05-11-2009, 09:31 PM
  #1980
fatboy's Avatar
Sweet, I've kept mine and wait for the 104
fatboy is offline
