Like Tree5Likes
Tamiya TB-03
Old 02-13-2014, 04:33 AM
  #2161
vadersing's Avatar
Default Gear diff?
Just want to check if anyone tried fitting TB04 gear diff in TB03?
Can't use SPEC-R ones for local Tamiya series.
vadersing is offline
Old 02-13-2014, 04:54 AM
  #2162
SteveM's Avatar
Trader Rating: 165 (100%+)
Originally Posted by zaraz
hi I have 2 complete brand new ball diff from the original tb03 kit, if anyone is interested, 35 usd shipped to you for both, pm me if interested
Payment sent for these on 02-10-2014.
SteveM is offline
Old 02-13-2014, 07:03 AM
  #2163
CraigMBA's Avatar
Trader Rating: 22 (100%+)
No problem, but you must use the tb03d spool 39t ring gear. They are fairly heavy.
CraigMBA is offline
Old 02-13-2014, 08:26 AM
  #2164
maxepower's Avatar
Thumbs up TB-04 gear diff in TB-03
I have it in my TB-03 right now and it works great, but I had to slightly modify the output shaft that the small gear makes contact with the ring gear. Yes, you have to use the ring gear off the spool which has a larger center hole to mount to the gear housing. the shaft makes a little contact with the housing so I just filed maybe .3 mm at most just until it clears, take too much off then the e-clip that holds the gear won't stay on the shaft. I used 3000 wt oil with the metal gears, the plastic ones wore out quick. Low maintanance diff is awesome!
Just my 2$
maxepower is offline
Old 02-26-2014, 10:50 AM
  #2165
Anyone got a recommended setup for outdoor asphalt?
inpuressa is offline
Old 02-26-2014, 04:58 PM
  #2166
Also I am looking for a setup for for my TB03r for carpet. Seems very loose at rear and steering is a bit twitchy.
Atechbh is offline
Old 02-26-2014, 10:29 PM
  #2167
CraigMBA's Avatar
More wing, or more rear toe.
CraigMBA is offline
Old 02-27-2014, 03:56 AM
  #2168
What rear and front blocks would you reccomend ?
For front and rear.
Atechbh is offline
Old 02-27-2014, 06:00 AM
  #2169
Trader Rating: 38 (95%+)
rear
rear back 1e block
rear front 1xa block
will give you 3 deg toe in
front
front front 1b
front rear 1b
mid track, no sweep,
also add all aluminum spacers if not already, and shim everything so there is no play
with the suspension blocks you need to play a little, and you will get them perfect without any play, if you do not get them spaced correctly, you can be off by .5 degrees on either side, not much but with a shaft car very noticable
zaraz is offline
Old 02-27-2014, 11:00 AM
  #2170
CraigMBA's Avatar
^ that's what I ran on carpet. If you need to free the car up, you can run a 1d in the RR position.
CraigMBA is offline
Old 03-02-2014, 09:51 AM
  #2171
The rear rear was an A so I switched it to a C. This should help.
Atechbh is offline
Old 03-02-2014, 10:57 AM
  #2172
Just realized I have an E block as well should
I use it in the rear rear or the C?
Atechbh is offline
Old 03-08-2014, 08:14 AM
  #2173
Tried the D block and it seems to work good
What about the front? Currently has B blocks
In front using on med-high grip carpet
Also is there any advantage to going to the
Carbon fibre damper stay?
Atechbh is offline
Old 03-08-2014, 03:50 PM
  #2174
Did I hear right that Tamiya is releasing this chassis again with carbon upper and lower decks or is that the TB04?
salvine is offline
Old 03-08-2014, 05:40 PM
  #2175
TB03Racer09's Avatar
Where did you here this? The TB04 went out of stock everywhere even though its a new car.
TB03Racer09 is offline
