Like Tree5Likes
Tamiya TB-03
Old 05-13-2017, 09:37 AM
  #2311
EbbTide's Avatar
Trader Rating: 39 (100%+)
Originally Posted by rzein
How are you fitting the gear diff? I tried doing it but it didn't work... do you have pic for It?
I'll try to get a pic of it today since I intended to work on my 03r anyway I did buy the car with the diffs already so I didn't do it myself, but from what I've read, there is just some grinding you need to do on the end of the prop shaft to make it fit.
EbbTide is offline
Old 05-13-2017, 03:53 PM
  #2312
EbbTide's Avatar
Here you go, this is what you do to get the TB04 gear diffs in. Really simple, just grind the flat end of the prop shaft just enough so it doesn't rub on the gear diff case and still allows you to get the e-clip on.
EbbTide is offline
Old 05-13-2017, 04:43 PM
  #2313
Thanks, I should try this.
rzein is offline
Old 07-16-2017, 11:19 AM
  #2314
Default New to TB-03 - suspension and differentials?
Hi I all,
I just picked up a very nice TB03 from eBay. It's almost specd to a tb03R. I got a good deal on it and am really looking forward to running it alongside with my other Tamiya chassis TA05v1 and Xv-01.
From what I read, it sounds like it's possible to use a rear carbon damper stay from the tb04. Right now the chassis has a carbon Ta03 stay, but it has very wide mounting positions for the posts. I don't feel like putting another set of holes in my 3 lexan bodies since they all get swapped around between my chassis.
The question is, does the tb04 carbon damper stay fit, and secondly, is the mounting position narrower, like the rear of a ta05?
Also I was looking to replace the front spool with a gear diff. I really enjoy the fact that this car came with a spool, a front one way, and a drive shaft one way. All this racing stuff for me to exploit. But there is something about a front diff that really changes the a driving and turning characteristics.
Does anyone have the correct part numbers to piece together a gear diff from the tb04?
So far I have put together:
#51549 - diff case, bevel gears
#51554 - cup joints (steel?)
#51553 - gasket (and 850 bushings?)
Is this all I need or am I missing something?
I primarily drive my cars on the street and I love the feel and low maintenance of a high CST front gear diff. The spool just seems to scrub my wheels.
Anyway, I hope to set my car up for street TC and maybe some light street rally.
4roller is offline
Old 07-18-2017, 09:01 AM
  #2315
EbbTide's Avatar
Originally Posted by 4roller
Hi I all,
Try using this to see what you need. This is the assembly in the manual. Should be able to get P/N's with this using the parts list in the tb04 manual.
EbbTide is offline
Old 07-18-2017, 09:14 AM
  #2316
Thanks vault boy
4roller is offline
Old 07-18-2017, 09:17 AM
  #2317
EbbTide's Avatar
Thanks vault boy
No sweat, happy to help a fellow vault scavenger
EbbTide is offline
Old 07-25-2017, 08:04 PM
  #2318
Default TB03 rally
TB03 cut up and running 74mm tires. My first shaft driven 4wd chassis.
Cuts were made to the chassis to allow the steering links to clear the extra rally droop. I also cut off the over hanging IFS bracing as it was interfering with the larger tires.
Front maximum height with 24mm Tamiya slicks is 22mm, rear is more. Chatter is gone because I went back to using the original arms but shaved down the constricting arms at the hub carriers.
I know, I need some better cable management.
Motor is a HobbyWing 13.5, with HW stock spec 100amp ESC. Servo is Futaba digital.
The front is running a spool that came with the car, and I hate it, it scrubs hard. A front gear diff pieced together will cost about 1/3 of what I payed for the car. So I will deal with it for now. All in all it drives very well on the street. Dive and roll are awesome. Not as predictable as a ta05 but a little better than the xv-01. Right now it's set with 72/35 gearing in 0degree blinky. It only gets faster when I enable turbo!
aracefan likes this.
4roller is offline
Old 08-26-2017, 05:05 PM
  #2319
Hi all,
Why is the spool so much wider than the diff and one way? What CVD length would I need for using non-spool? 46mm?
4roller is offline
Old 08-27-2017, 08:10 PM
  #2320
TB03Racer09's Avatar
make sure you use the right holes in the drive cups, if I can remember correctly, there are 2 pairs of holes and they are offset from each other.
Im running 44mm shafts with the stock ball diffs, fits perfectly
TB03Racer09 is offline
Old 08-29-2017, 08:13 PM
  #2321
It looks like the spool and one way I got with my car had different widths. I picked up some diffs and another one way and spool for a tb04. You can see the width of the one way drive inserts vary. The 44mm CVD is correct, but if you have narrow drive inserts you need 46mm.
I ended up using the gear diff in the front and a ball diff in the rear the car rotates very well now.
4roller is offline
Old 07-27-2018, 03:31 PM
  #2322
Someone know where I can find the alu steering set #54095?
pozhar is offline
Old 11-03-2018, 12:21 AM
  #2323
Einsman's Avatar
Anyone have TB-03 parts for sale? What TB-04 parts fit the TB-03? Any other Tamiyas have parts that fit a TB-03?
Einsman is offline
Old 11-03-2018, 12:32 AM
  #2324
Bulkheads and diffs fit from tb04/05, suspension from TRF416 is used on varety of Tamiya cars, basically only TB03 specific part is chassis, steering, motor mount and centre shaft.
Papi is offline
Old 10-30-2019, 01:51 PM
  #2325
Hi guys,
sorry for grave digging but I wanted to share some pictures of my recently updated and finished TB-03 with you.
Some weeks ago I have decided to do a kind of "Box Art Car" out of my parking lot racer TB03. I was stuck the some of the original TB-03R pictures, which can be found online and tried to use as many contemporary Tamiya parts (TEU-302 BK for example) or recent replacements with similar appearance (TRU-08) as possible. I'm nort sure about the "Lightly Tuned Motor", but colorwise it fits neatly in the overall picture.
I would have loved to add one of the old Tamiya NiMH 3700mAh battery packs (part number 55094), but sadly, i wasn't able to find one of these.
I have updated the car with TB04 gear diffs, both are equipped with the steel bevel gears and cross shafts, the front unit is further updated with Aluminium cup joints. I also replaced the stock dogbones shafts with universal ones, 42mm front and 44mm ones in the rear.
Other nice blue updates can be seen in the pictures.
The result:
Some more pictures can be found in my TB-03 album.
I'm curious what you think of my "TB03 pro" :-)
Regards,
Michael
SteveM, Papi and walrusjon like this.
JJ100179 is offline
