Tamiya TB-03
#1981
hey everyone.
its a shame that the thread has seemed to die off.
hopefully it can be brought back to its former glory.
i have a question. I'm running the tb03 obviously and i am getting new c hubs for my car. but i see that there are multiple degree options. i am just wondering which ones people recommend?
any help would be much appreciated!
cheers.
cheers.
#1982
hey everyone.
cheers.
cheers.
Grap the 416,417 hard uprights at 4 degree and u cant go wrong...get 3 sets if you like to hit stuff.
Part no 54031.
#1983
hey great to hear people are still running the tb03!!
so you recommend getting plastic ones? not upgrading to aluminium??
cheers
cheers
#1984
hey all i can find is 4degree c hubs which is what i want but they say they're for the tb5!!
they look very similar, can anyone confirm or deny that they will fit?
if not anyone got a part #?
cheers.
cheers.
#1985
So the hard front c hub upright (54031) says its for the TA05 IFS or something.
Best just to download a 416 or 417 manual and get yr part numbers from that.
http://www.tamiya.com/english/rc/manuals.htm
#1986
oh okay sweet thanks!
that helps heads. great idea i didn't think of that.
cheers.
cheers.
#1987
The TA05 are plastic and the TRF416/417 are CF Reinforced. The plastic ones gives you more flex when you crash.
I still have my TB03
#1988
yer sweet thanks.
i was leaning more towards the aluminium parts. mainly cause they look nice haha. and i don't race much so i don't have big crashes. but i guess if i find any aluminium parts break i will goto the carbon reinforced parts.
I've been reading through the old pages of this thread, if only it was as popular as it was before. the tb03 is an amazing car.
anyone still racing theirs or just bashing?
#1989
yer sweet thanks.
#1990
awesome great to hear that it still out there. yer i know its an awesome car! how it go in the races?
#1991
#1992
oh yer i know its the driver more than anything. but a good chassis definitely helps! and the TB03 is definitely a good chassis. but thats a bloody good effort on that guys part.
#1993
TB-03 vs. TA05 V2
Long story short, I bought a TB-03 a year ago and thought the car was the best sedan I ever drove. At some point I lost handling and gave up on it, right about when the TA-05 V2 came out so there it sat for a year until now, cleaned the cobwebs and dust off of it, found several bearing siezed and went through the whole car. Just took it out on the track today and the car was amazing again. Now I'm not sure if I want to run the TB-03 or the TA-05V2 for TCS here in So. Cal. Need to do some serious comparison to find out which I like best! Tried asphalt and now going to try carpet this weekend! We shall see!
#1994
Go for the Tb03!! ive swapped several times over the last few years between a Ta05 and the Tb03 and the Tb03 always feels a bit better, it just rotates a little faster mid corner.
Heres a tip, I tried using the older longer arms on the front and it smooths out the steering a bit. Use a x or x-a block and 4mm hexes to get the pivot point right inside the tyre.
#1995
RE: TB-03 vs. TA05 V2
The TB-03 has always seemed quicker but the TA-05 is easy to drive in the corners and very consistant.
I'm confused on what block combination you said to try in the front. Right now I'm using C blocks in the front with slight kick-up in the front block of .5mm. I might take the spacer out of the front and allow the car to dive more into the corners. Then maybe move the steering turnbuckle forward hole to increase the response even more.
Saturday I'm running carpet so this could change everything because all I said about the cars handling was based on outdoor asphalt. I'm still experimenting with tire and insert combo for carpet, so this may change my thinking on set-up.
I hope all this makes sense to you. I'll let you know my results after Saturday. Then maybe back to asphalt on Sunday!
Isn't RC cars a blast!
