TRF414M, 404x, 414, 414X
#841
TRF_SPAIN the URL is www.tq-racing.com, but as mentioned previously it's not updated yet.. should be coming by end of this week.
pUs: Yes, they World Champion Replica kit will include new dampers just like waht Surikarn used at S. Africa, BUT they may still be anodized in blue. The difference is the coating inside!! They use an advanced coating making the dampers run much smoother and less leakage.
Jack, marvi: the main reason of running aluminum pulleys is the much less friction they offer. They are definitely much better than the plastic ones.
Regarding the diff protection seals, there is one manufacturer from Japan who makes them specially for TRF414M / TA04. Drop an email to [email protected], they should be able to give you more info.
Cheers...
Cheers...
#842
Hi guys, do you know where and how much i can get a 414m original version?
i found one in ebay with a abc hobbdy arrocrd wagen(really cool!)....http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1741448826 do you think i should bid on it and what do you think the limit is?
Thanks!!!
Thanks!!!
#844
Originally posted by marvi
thanks one more thing, is there a way to shield the rear ball diff? i saw the x-ray diff and it has "labryinth-seal flanges." has anyone fabricated something like that without binding the diff outdrives? im thinking of using scrap lexan.
also, what is the wt equivalent of the yellow shock oil? i use 40, 60, or 80wt when tuning my cars but i have no idea how to compare this to the "yellow #400" tamiya oil.
ATLAS MH7-605, unit price 250 yen
Each pack is enough to protect 2 diffs. It is made of re-usable sticker. Judging from the feel when assembling, probably you can reuse it more than once.
#845
Thanks!!!
Thanks!!!
Do you know him? I think you do? Sending money to this guy's big brother in Texas sound familiar
#846
thanks, ill look for those. i think one of our lhs carries some atlas products. i tried sticking lexan diff shields with double sided tape but ill find out if they work when i run this weekend.
#847
Well, cover the diffs is even easier that make lexan covers...just use a sticker!!! take the size of the outside ring, then of the outdrive and put if with the diff completely mounted...i did it on my car and looks great! oh!! my sticker was transparent and i dyed it on black,but maybe...blue is better
#848
oh yeah, that idea's much better i think i have some thick vinyl stickers here that might work. my lexan shields look like crap, its difficult to cut the round shield without lexan scissors.
#850
is it a good idea to polish the aluminum suspension mounts of the 414M? it looks like a rainy weekend. i cant run outdoors and im looking for something to do this weekend. i saw that the rear suspension block has something like a clearcoat finish that seems to have faded. i was wondering if i can use metal polish to shine it up. since im on the subject, anyone here polished all the aluminum parts (bulkheads, etc.) on their 414M? how did it turn out?
#851
I've tried to polish it once, but once the clear-coat wears off, the aluminum gets tarnished very easily, after a week or so, if you want your aluminum have a polished look, you'd have to polish it every now and then so it won't get tarnished. I personally got tired of polishing it every time, since you have to tear it down to do so.
I had mine recoated with a clear ball-burnished coat, like what bicycles have. it's shiny,like the polished look and it doesn't tarnish at all.
Tamiya calls their coats satin finish, which is more like a matte finish, but has a little "gleam" on them.
#852
whats the best tamiya car?
#853
Works the same, and has a nice soft feel to it
shrekair: best tamiya car for touring, rally, offroad etc.etc.?
#854
TC
#855
I'd say the best Tamiya car, for racing would be either the 414MII or the TBEVO II. since they're Tamiya's top of the line cars.
For play, It would be the TL01.
