New Jaco Rubber Tires >
Old 07-03-2008, 11:35 AM
  #286
Trader Rating: 90 (100%+)
Originally Posted by CaliberX
My club runs indoors (carpet) and only JTG is allowed. What compound would be recommended (Super Stock 13.5).
Thanks for the info.
Greens are going to work best on carpet. In theory!
RBLove is offline
Old 07-04-2008, 12:33 PM
  #287
Shop Owner
FTTim's Avatar
Trader Rating: 31 (100%+)
Kind of interesting IIC hasn't announced the compound for vegas yet????!! Maybe I'm not out in left field with my Jaco Blue comment after all. Time will tell.............
FTTim is offline
Old 07-04-2008, 03:27 PM
  #288
You're probably right. If you think about it the RP30 was good on asphalt and carpet.
RBLove is offline
Old 07-04-2008, 06:35 PM
  #289
wallstreet's Avatar
Trader Rating: 24 (93%+)
I dont think you are cause guys were saying the old blues were good on carpet and were faster and had a better life cycle.
wallstreet is offline
Old 07-04-2008, 07:52 PM
  #290
The blues work well on carpet. I am waiting for a few more test results before we decide, but even if greens are a little faster, blues are easier to obtain on a consistent basis. This reason alone makes them very appealing as a spec tire. I will be discussing this with Scotty soon.
Supply on tires is now reaching the point where you should start seeing them in shops on a more consistent basis. We have good stock and all we need to do is keep up with the mounting (uuugghhhh).
Jack Rimer is offline
Old 07-04-2008, 10:18 PM
  #291
JayBee's Avatar
Thumbs up
Hey guys what compound are you finding works best with the blues?
JayBee is offline
Old 07-05-2008, 12:18 AM
  #292
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
traction compound?? for asphalt i clean them with WD-40 then let it dry then apply buggy grip, let dry then hit the track
Marcos.J is offline
Old 07-06-2008, 08:53 PM
  #293
bobbyvegas's Avatar
My friend was using the 36's and the car had great grip, may need to buy a set..
bobbyvegas is offline
Old 07-06-2008, 09:00 PM
  #294
bobbyvegas's Avatar
Interesting, my Crew and I clean ours with simple green (sometimes alcohol) and then apply the JACK. Amazing grip considering the Tarmac here averages 130+ degrees while racing. I will try the WD-40..
Old 07-06-2008, 09:01 PM
  #295
Super Moderator
Marcos.J's Avatar
ours was 143 degreea today last month it was 161
Marcos.J is offline
Old 07-06-2008, 09:34 PM
  #296
Which of the Jaco's were you using (blue, green, etc) in this type of heat? TIA.
alang is offline
Old 07-06-2008, 09:49 PM
  #297
Trader Rating: 38 (100%+)
A few of us were trying the blues on a track that was 110 (sealed asphalt, ambient temp ~75, treated with VHT) and they werent working well for us. We could have used a softer compound I think. The cars kept wanting to break loose on us. We all went back to tires that we had used previously. They were slightly better but still a little loose (just not as much). So I think it was partially the track too. Going to try again next Saturday when it should be warmer and hopefully the track will go back to its typical self. Tires did wear well and hold up great. As well as look great!
or8ital is offline
Old 07-07-2008, 04:07 AM
  #298
Trader Rating: 47 (100%+)
humm... i used my blues all day saturday on sealed aspahlt with 75 degree and our track was around the 110-120 range and mine worked great... maybe it was the vht lol
-DC-
smitty2802 is offline
Old 07-07-2008, 05:44 AM
  #299
speedybill's Avatar
Trader Rating: 73 (100%+)
Wink
-DC-
HMMMM
I used my Sorex 36' all day with no problem
speedybill is offline
Old 07-07-2008, 06:21 AM
  #300
-DC-
It may have been. The sprayer has been acting funky. Perhaps it didnt mix well this week. The VHT is usually very tacky and it never got that way this week. Perhaps b/c it wasnt sunny so it didnt evaporate.
Just gotta try it again next week.
or8ital is offline
