Tekin RS ESC sensored
I'd be careful running the X12 without changing the insert first. I span it up and it was overtimed with the 0 insert on 30 boost (40 on the motor by default apparently) so with the above setup, you've got 75 degrees at the top of the boost range, then another 10 at full throttle (85 in total)
Try it by all means, but temp it after a minute or two. Personally I think it's too much timing.
either the motor or timing boost,try 10 and turbo 10 and watch temps
I sense a TEKIN lock in, no one is allowed to leave HQ until the next shipment of equipment is ready to get out the door...
I have run the Nosram version of the 10.5 x12 a few times now, with the standard timing insert and circa 40 on the timing.
It has never gone above 50degC and outside on a medium sized track was a missile that still never really got warm.
Remember, the x12's have a lot of torque so the gearing can be a bit taller than some other motors.
Skiddins
Skiddins
Skiddins
Because, as we know, the powerband will differ...
Jeff Cuffs snowbirds ESC settings
Does anyone knows where can I find Jeff Cuffs ESC 17.5 snowbirds settings?
Thanks!
Thanks!
Not sure if you're running on or off road. Remember high end servos can have very high stall currents. I use JR servos as well but have never had any problems. I think your problem is a cumulated drain which surpasses the available power. Remember some radios drain more than others too (for example some Spektrum receivers pull higher currents than expected).
Check if the esc wires are capable of delivering in excess of 6A to the radio so the servo is properly powered and assess if you should change them. I changed mine to a wire size equal to that of the servo I use (which is clearly heavier gauge than the little wires the Tekin comes with).
A powerful capacitor might just get you over the drain spikes but I don't regard it as a permanent solution if this is your problem.
Basically, I need to keep a close eye on my Castle setup, would i need to keep as close an eye on this one?
And thank you for the info.
When I ran in the GT10 (before v203) I could never get the motor temp above 45degC no matter gearing I tried, from 45mm/r to 85mm/r
Skiddins
