Tekin RS ESC sensored
That is weird. I had a friend of mine got his to 220 deg F at one point and his is still kicking strong. I guess it is the luck of the motor. I cooked a Checkpoint 17.5 at 200 deg F when I switched to v203 and a Trinity Pulse 17.5 at 190 deg F when I got my Tekin and downloaded v200.
4 x 1,20volt nominal is 4,80 volt and if it gets charged it will be a little higher i gues ?. Same as 2s lipo is rated as 7.4 volt but when charged it is 8.40 volt before it drops.
I'd believe it. They just seem to come to a crawl at 155*s for me. I was talking to Brandon Shells about it and he said he found the same thing. I have had mine up to 172 degrees when my fan stopped working. It seems to still work fine but I was concerned. Kind of makes me want to go back to a Duo because those seem to be fine until a little over 200*.
But back to the Tekin discussion, does Ken surf these boards? I'd like to see what he ended up with for settings if he doesn't mind sharing.
My 17.5 1s Settings in 1/12th scale was:
Orion 17.5 Middle Timing Mark
Timing Boost: 50
RPM Range: 2300ish-5800
Turbo: 4
Delay: .3
Ramp: 2.0
Push: 30
I just tried Jeff Cuffs' 17.5 rubber on carpet setup and Its right on the mark. Temps were at 160* on my Redline @ 5 minutes. I practiced for another 5 and the temps were still only 170*. I may switch from a 5.8 FDR to a 6 just to see if there is any real difference in performance.
Thanks again to Randy and Jeff for their support.
Ok guys I have tried to do as much reading as I can but there is an overwhelming amount of information in this thread. I am starting to get a better understanding, but am still somewhat confused. What I would like is a good baseline setup that I can start with and tune from there.
The track I am running on is 72x45 with a good flowing layout with 2 180* corners. I am running a Novak 17.5ss motor with stock timing in a CRC gen Xl 12th scale. 1s lipo and a FDR of 2.75.
My first question is what is the timing of this motor and should I adjust it differently? Second, does my FDR sound about right or am I off there aswell. Third, what would be a good starting setup on my Tekin RS with software v203? Not affraid to make changes I just need a good starting point as no one locally has any suggestions for me.
fx speedy 2.03
hi
is there any site that explains the difference in settings for a 2.03 rs tekin esc. thanks
My V203 setup for VTA/21.5/lipo
I got this setup via a A main racer that is well know in all classes .Is this one gonna smoke my rs speedo or will it be good to go with ????.Im kinda nervous to put it on the track so if theres a Tekin rs guru that can set me in the right direction that would be great.
VTA class
v203 software
AE TC5
novak 21.5
reedy 5000 mah lipo 35c
4.6 fdr 43/100
drag brake #4 with one way
brake strength 100 % 40 in radio
neutral width 0
voltage cut off 2c
motor type BL-FW
throttle profile #3
Sensored
timing advanced 18
reverse strength 0
push contol 0
timing boost 0
turbo boost 0
turbo delay 0.2
end rpm 9002
start rpm 4082
turbo ramp 1.0
thanks in advance
Matt R aka blackdog
VTA class
v203 software
AE TC5
novak 21.5
4.6 fdr 43/100
neutral width 0
voltage cut off 2c
motor type BL-FW
throttle profile #3
Sensored
timing advanced 18
reverse strength 0
push contol 0
timing boost 0
turbo boost 0
turbo delay 0.2
end rpm 9002
start rpm 4082
turbo ramp 1.0
thanks in advance
Matt R aka blackdog
It's not 5 cell, I might have unwittingly exagerated the fully charged voltage.
The sticker on the battery read "1/3AAA 150mAh 4.8V Ni-MH". I just checked the pack voltage (car was raced last Wednesday and not touched since) 4.39V. Hooked up the charger and about 5 mins later @ .5 amp, 6.43V. My local Hobbytown sells them for the Losi Micro T for $10. I think these would require recharging between rounds without fail, and from what can be determined through the heatshrink, would be a 4 cell.
Back when this 1S LiPo movement invaded 12th scale, this was the first thing I tried because it was laying around. I know there are like 5cell, 350 mA Batteries out there, but these were convienent and so far, been dependable. The "Cheese Ball" connecter needs to be changed though, and I, plug it straight into the Rx to powerup.
Updating the software is something you can't stop. If you unplug it during an update it can "blank" it out.
If you managed to blank you two RS's it may be a bad Hotwire, or bad software on the PC being used. Hard to say without being there or using them.
I would like to see both of you try a factory reset.
i know what the delay does but what about the prfole and ramp?
also i have my 13.5 now at start of 5400 and at 18500.was at 0.5 delay.but car wasnt coming alive untill the end of the straight.i turned the delay to 0.3 and added 3 clicks to motor timing and 3 clicks of boost.alot better.
what effect would i feel by lowering the start/end of rpm range?
