Tekin RS ESC sensored >
Old 01-22-2010, 10:24 PM
  #11026
morris's Avatar
Trader Rating: 44 (100%+)
hey i have an interesting question.im just got done racing tonight.and i noticed something weird with the performance and was hoping to find an answer.for a 5 minute heat.im guessing about 2 minutes in it went from hauling balls to feeling like the car didnt have turbo anymore.so i was temping after each race.it was temping at 147d.
i then got into the hotwire and turned down the timing which was set at 50.turned it down to 40 and the balls to the wall feeling was gone.but still felt consistent.temp was the same.....
any ideas on what it could be?
cause if i can get the car to feel awesome like the first 2 minutes that would be great.
any help would be great.....thx
morris is offline
Old 01-22-2010, 10:26 PM
  #11027
STLNLST's Avatar
Trader Rating: 32 (100%+)
Car is ready for Sunday's action Time to represent fast, enjoyable fun to all come Sunday.
STLNLST is offline
Old 01-22-2010, 10:31 PM
  #11028
cannon's Avatar
Trader Rating: 35 (100%+)
Maybe this sounds a bit obvious ... but what batteries were you using and how old are they? That can make a difference to performance
cannon is offline
Old 01-23-2010, 02:10 AM
  #11029
mark79's Avatar
Can someone recommend a net book that would be suitable for running Hotwire on trackside?
I'm not keen on carting around a MacBook so I was thinking of something small say a 7 inch net book.
mark79 is offline
Old 01-23-2010, 02:14 AM
  #11030
amnesia's Avatar
My friend runs a cheap (sub £200) Acer netbook with Hotwire just fine... all you need is a reasonable screen resolution so that you can view all the settings and a usb port.
amnesia is offline
Old 01-23-2010, 02:18 AM
  #11031
I use a Asus eeePC, with very good results, i program Tekin, see TV, listen music, etc...at tracks, the models 800 - 900, are discontinued, but are in the shops at good price, and have a litle performance as well litle monitor, but make the job. It use Win XP.
Anyone, use Tekin´s modified motors, 4.5 - 5.5 at high competition level, and how it permormer, compare with Lrp, sp modified motors, i have a 10.5, and race with it at National last year in stock, i finish 5º in National and this motor help me a lot, but never i tested or see a Tekin modified, and i don´t know if performance is similar to other brands.
Greetings, Luis C.
luic is offline
Old 01-23-2010, 02:38 AM
  #11032
razzor's Avatar
are you using turbo ??
If not then look at dropping a couple of teeth on the pinion
If yes dont use turbo and see what happens.
Another thing that tends to get the motors hot is having the timing come in at to low a rpm.
razzor is offline
Old 01-23-2010, 03:41 AM
  #11033
TrevCoult's Avatar
I'm using an Asus EeePC 1001HA, running Windows XP. 10 inch screen but definitely small enough, works perfectly and screen is just about big enough to do other things with it too.
Trev
TrevCoult is offline
Old 01-23-2010, 03:59 AM
  #11034
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
if turbo is on your radio is wandering add 10 to the end point of the radio,if you cant set it at 90 recalibrate and set it back to 100
20 SMOKE is offline
Old 01-23-2010, 04:09 AM
  #11035
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Originally Posted by SteveL
On our small track, 66' straight, I have the start rpm at 2,490 and end at 9,000, boost at 45 and no turbo. Roll out is 64-65mm with a Duo 2 timing set to one notch above middle. Car is very fast and temps end up around 130-150 after 8 minutes. I tried the timing on the motor at 0* but it was just slow. I also smoked a Duo 2 with the boost at Max and Turbo at 10 so there is a window that you need to be in, just not sure where that window is for your track.
Well this particular track, the longest straight is 44 feet, but a tight infield, so i need torque!!!should i change the rpm's slightlly cause of smaller straight, and wich way to go with that, the rpm's are whats gettig me THANKS for response...Tommy
TommyBlazin is offline
Old 01-23-2010, 04:19 AM
  #11036
20 SMOKE's Avatar
you have experiment a little ,go with a 1500-2k start 6-7k end
20 SMOKE is offline
Old 01-23-2010, 04:42 AM
  #11037
k_bojar's Avatar
Trader Rating: 30 (100%+)
Trev
+1 on the Asus netbooks, I got the same, and it works out perfectly for the Hotwire and watching movies while waiting
k_bojar is offline
Old 01-23-2010, 05:10 AM
  #11038
cyclone x's Avatar
i use the ACER and its great
cyclone x is offline
Old 01-23-2010, 05:40 AM
  #11039
+1 on the Asus EePC...cheap (about $250), small (barely know its in my backpack all the time), and does all I need for portable machine...Only comp I carry now...
markg is offline
Old 01-23-2010, 06:52 AM
  #11040
tallyrc's Avatar
everytime you calibrate your radio after adjusting your esc settings, set your throttle epa to 90 or 95% and calibrate. once the settings are set, reset your radio for 100% and race.. even though our radios are digital the pots in the trigers have some variance and your probably not always hitting 100%.. that make sense?
tallyrc is offline
