Tekin RS ESC sensored >
Old 01-08-2010, 07:33 AM
  #10276
tc3team's Avatar
Originally Posted by Jeremy Otis
I totally agree with this as well. I have run version 198 against the newer versions and have had very good successs in single cell 13.5. Simple to set up and get right and very fast. On a small track it would be interesting to see how it would fair against v203.
Don't get me wrong though, every updated version of software has something new to offer and can make your car faster in the right environment, but I don't like to overcomplicate myself with the options It's good to know the software is on a constant development curve.
i've heard good things that it can make the motor work at a cooler temperature too, which is always good.
I don't see newer software as an easy fix to making the car faster either, if you're happy with how the car is going then stick with what you have, but if you feel the need to upgrade/like the technical side of brushless and/or want to learn what the newer versions have then thats cool
Theres never going to be 1 single answer to getting a good result, everyone has their own way of doing it
tc3team is offline
Old 01-08-2010, 07:42 AM
  #10277
wingracer's Avatar
Trader Rating: 24 (100%+)
I wouldn't say this new version isn't better on a short track. The testing I did Monday with a friends 1/12th scale on a small track with the new version gave more infield rip then I have ever seen in a brushless car. Well set-up Tekins have always had great top end but the advantage with his car was the speed in the infield. It felt like an old brushed mod car. Despite the chassis being a bit off, I was running TQ times with his car. I'm dropping a nearly identical speedo/motor set-up in my car right now and have high hopes for a victory this weekend.
wingracer is offline
Old 01-08-2010, 08:00 AM
  #10278
DriftDreamer06's Avatar
Originally Posted by MarkBrown
I'd really like to see a motor timing calibration capability in the firmware. If there isn't room for it, then put out a firmware version that *only* does motor timing calibration, and we can switch to that version when we need it, then switch back. You only have to calibrate each motor once, after all. If you read over this thread you'll find that a significant fraction of the problems are caused by confusion about how much timing is in the various brands of motors.
this is a great idea! please
oh and a little data logger? rpm and time
most important Thanks Tekin
DriftDreamer06 is offline
Old 01-08-2010, 08:01 AM
  #10279
Exactly! There is a progression in the adjustability of the software that offers each driver a chance to "learn" and try to move forward. The tune-ability and drive-ability of the newer v203 is apparent. Those that had a real good setup for an older version might not see as dramatic of a leap forward, especially on smaller layouts.
The interesting thing on my home track (small) listed in the earlier post is the comparison of the setups of v200 and v203. In v200, I was using o* motor, 25* Boost, 20* Turbo and a 0.4Delay. I was guesstimating that my Turbo was "hitting" at around the 35' mark of WOT. With v203, I have 0* motor, 50* Boost, and tried Turbo various settings at 0.7 Delay (caused to much heat) and 0.8 delay (came on at the 60' mark of WOT which is where I need to get off the throttle for a corner). My point - The progression of the software setups matches up with my tuning needs on my track. As an aspiring intermediate level driver, we (I) need to refer to my notes and setups often to make sure I'm not venturing out into Right Field.
VRacing is offline
Old 01-08-2010, 08:15 AM
  #10280
tc3team's Avatar
If you are in the sharp end of the A final, and usually looking for tenths of a second, the newer software can help in the right application, but not everyone has that ability or technical know how to get the most out of newer software or a consistant lap time to utilise it well enough.
If you install the newer software and feel a bit lost by it, you might then need to reinstall the older version to find your feet again.
Jump when you need to, not because you feel you have to because that is what everyone else is using
The newer software was designed because in some situations, the existing software wasnt good enough for the best racers that go to big events.
More ajustability was needed, and the new software delivered that
Most of all though, have fun and enjoy your racing! Don't overcomplicate things unless you have the time and desire to. Racing is one big learning curve.
tc3team is offline
Old 01-08-2010, 08:23 AM
  #10281
Team Tekin
Tekin Prez's Avatar
We intend to make some easy buttons in the hotwire so you do not have to mess with the advanced features.
We also intend to put a set of 'TimingProfiles' right on the esc so you do not always need a Hotwire. 'Timing Profiles' 1 -13 that are increasingly aggressive in replace of the 'Throttle Profiles'. Low 'Timing Profiles' for mod and high 'Timing Profiles' for spec like everyone else, but still a lot more choices to dial it in
That means the preset 'Throttle Profiles' and 'Custom Throttle Profiles' will only accessible thru the hotwire. The preset throttle profiles can also be created with most radios using the 'expo' functions.
Tekin Prez
Tekin Prez is offline
Old 01-08-2010, 08:36 AM
  #10282
tc3team's Avatar
Sounds neat
I think the main thing is, simplified terms on what the new features do is very useful and hovering over different parameters explains things well
"The geeks and the less geeky racer" are two very different breeds of r/c racer
tc3team is offline
Old 01-08-2010, 08:52 AM
  #10283
Tekin Prez
Will there also be a save function so we can save our setups and send to other drivers?
Data logger is great. Can it also give the speedo temp and motor temp?
Also were the motor needs the most power?
That helps with finding the right gearing and boost settings.
mikky32 is offline
Old 01-08-2010, 10:38 AM
  #10284
Tekin Prez
That's awesome! You guys listen and take action!
jeffb is offline
Old 01-08-2010, 10:55 AM
  #10285
Grenade10's Avatar
Trader Rating: 40 (100%+)
I used one to help "Dial In" the 203 software in an oval car. Has very good information on RPM, Voltage and I used just one temp point on the motor, but comes with a harnes that would give you multiple temp points. Found very usefull, just need to see how to "Shoe Horn" it into my 1/12 scale.
Grenade10 is offline
Old 01-08-2010, 11:33 AM
  #10286
WIITA's Avatar
Trader Rating: 43 (100%+)
Imagine if some software could be created where after a few quality laps around the track you could pull the car off, plug it into the esc through hotwire, and bring up a graph where you could see your throttle curves all laid out on a chart on the screen and set your rpm range just by looking at the curves presented to you. And all of the guess work is behind you espically if you go to another track or change track layouts periodically. HINT HINT. Thanks Tekin!!!!!!!!!!!!
WIITA is offline
Old 01-08-2010, 12:02 PM
  #10287
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Another suggestion for Tekin folks... on the RS2 and Hotwire2 when you release them many moons from now, I highly suggest NOT using the receiver plug as the interface into the hotwire... its a pain to plug in, plug out, plug in, plug out when doing track testing. Maybe a camera style USB plug right on the side of the ESC would work so you could leave your car as is.... perhaps even have the car on AND be hooked up to the hotwire at the same time?
Thanks Tekin.
Cpt.America is offline
Old 01-08-2010, 12:06 PM
  #10288
I think you will find the Robitronics Icube already does this, so it can be done, What do you say Team Tekinthat would put you well out in front!
Toolmannz2 is online now
Old 01-08-2010, 12:10 PM
  #10289
Thanks Tekin.
+1 The Icube has a mini usb built into the on off switch so no removing any wires
Old 01-08-2010, 12:37 PM
  #10290
marcel p's Avatar
great idea
the in and out servo plug bugs me also great time
is it posible to do it with a y servo cable?
marcel p is offline
