Tekin RS ESC sensored
#4891
What operating system is on your computer?
Max timing boost is 30 degrees.
Dual mode is mostly used for mod racing HOWEVER Donny Lia often runs dual mode with the Timing Advance at 100 (which is 30 degrees period, motor timing null) and wins the 17.5 GTP classes this way.
Most spec setups are 10 degrees or so in the motor and 25 on the timing boost. With 200 this will change quite a bit. I'm going to post team driver setups when 200 is released just for this reason.
For 1s setups YES the check box must be checked, motor setups don't change for 1s.
#4892
If that question is addressed to me, then here it is. See post below.
This happened to me too. When I set my speedo to Max boost and hit apply, it saved. But as soon as I unplug and plug it back in to make sure that it did save. It gave me your settings are out range ... blah blah blah.. or similar to that text. I check the boost and it is set to 0. Mind you, my settings are set to:
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
When I pulled the trigger just to test it out on MAX settings, it "sounded" it has more rpm and umph. Then I plugged it back in to check my settings again just to tinker with it, it gave me the above error. The hotwire set my speedo to 0 boost . So I got scared that I might fry my esc and just set it to 30 - "sounded" less rpmish; less umphish.
Sensored
2s lipo
6.0 cutoff
10 NW
drag 20
brake 80
Forward only
0 deg motor timing
Hotwire 3.25
V. 198
WinXP Pro SP2
#4893
He asked what operating system your using on your computer...not the ESC's setup. As in are you running Windows XP, Windows Vista, Windows 7?
#4897
So I'm trying to upload 198 software and my ESC is not finding it... Im trying to get rid of 199 software and in my "other versions" says 178 and 180... How do I get the 198 software???
also if I try to make changes in my ESC is keeps saying JIT(just-in-time) debugging error.... What the crap is this?
Alex
Alex
#4898
Could someone answer my ?'s please... Im in need of help bad
Alex
Alex
#4900
Already did that once tonight and it did the same thing... Same error message wouldnt update and 198 did not show up...
Alex
Alex
#4901
Alex,
I'm thinking you've got Vista. Check out this How To vid:
http://www.youtube.com/watch?v=tTp3tUL9u8Y
Your problem is that you don't have the most current software with 198 in it:
www.teamtekin.com/hotwire.html
The RS and RX8 share some software directly but ALL current Tekin speedos are covered in the hotwire software. So one download for all escs.
Bukil: How long ago did you download your 198?
#4902
I have visa 32bit randy......
Alex
Alex
#4903
OK thanks Randy Tekins support really is top notch... the video cured the problems I was having...
I'll never own any thing other than Tekin again... Customer support is EVERYTHING these days and you guys HAVE GOT IT!!!!
thanks a TON!!!
aLEX
thanks a TON!!!
aLEX
#4904
saw two of these escs in action today at my track. they pulled 10ft on me on the strait. so now i have to have one. does the hotwire interface work on Mac's. thats all we got. is this esc just as adjustable using the buttons on the esc as tuning on the computer. it looks small, powerful, and convenient.
