Tekin RS ESC sensored
#4861
#4862
O.K.
I Just purchased an RS and have a few questions. Should I be running 198 or 194 for single cell 13.5/17.5?
Also, what should I set my boost at? Should I go with Max boost or run at it at 30? I will be running my motor with zero timing.
Also, what is a good drag brake setting and also a good brake strength setting?
Thanks,
Travis
Thanks,
Travis
#4864
O.K.
Thanks,
Travis
Thanks,
Travis
Max boost
No drag brake
Full brake, adjust out in radio if you need less.
#4865
O.K.
Thanks,
Travis
Thanks,
Travis
No Drag brake and full brake, no timing on the motor.
I hope that helps
#4866
I run v194 wth a 17.5 on full boost, I run a slightly lower gearing but it really depends on the motor you are running, a Tekin or Trininty you need to run a lower gearing compared to a Novak or an LRP, make sure you keep a check on the temp after 3 min.
I hope that helps
I hope that helps
Why no drag brake? Is there are reason for this?
#4867
Increases motor temp quite a bit, if you can get away without it, the motor will run cooler and you may get away with a tooth bigger!!
#4868
and make sure you recalibrate radio to esc again after changing settings on the RS.
#4870
Cheers
Adrian
#4872
Hello all.
Yesterday tried RS PRO' with Redline 4.5.
We do not satisfied with the performance of the motor and regulator.
Setting you some advice?
Final report with XRay T009 9.86 \ 9.24
Our track and: ( www ) miniautodromopadovauno.it
configuration : TARGA FLORIO.
HELP ME !!
HELP ME !!
#4873
I run RS and RS Pro's in all kinds of oval and pan car onroad, heck even in a vintage trans-am car, so a fellow racer asked a question about running a 3.5 in a touring car.
I said to run the Pro, keep the heat sinks open to air, add a second capacitor and run in program that does not put "Boost" (can't remember the name). Does this make sense? Is there some other setting or different set up for the caps that should be done.
Anyone run something similar?
Thanks in Advance
Thanks in Advance
#4874
My RS pro whit two condensers, fan front posts and motor Novak Ballistic 3.5T, to spend 3 minutes, my RS cut for temp. ratio 10.20 use lipo 5000 30C, large track environment temp 22ºC. Mode Dual, timing ESC 10
#4875
Set it in dual mode. set the timing around 40.
Put a fan towards the solder post. this will keep the speedo cool.
This works great.
