Team Magic E4 Thread >
Old 06-09-2011 | 07:44 PM
  #3781
td-civ's Avatar
i got my pack to fit it was a pain im the a$$ but its in cant run it yet as one of the arms are cracked so i need to get some
if you guys have extra lower arms front and back that your willing to sell and any other parts that i wi;ll need as back up let em know ill buy them off you guys
here is the list of k factory part im going to buy let me know if there is anything more i should get
7075 Adjustable Single Bell Crank Steering Set (k2121)
E4 Alum. 7075 Steering Block Set (k2110)
E4 Alum. 7075 Middle Shaft Mount (k2103)
E4 Alum.7075 Rear Bulkhead Upper Mount (k2144)
E4 Alum.7075 Front Bulkhead Upper Mount (k2143)
td-civ is offline
Old 06-09-2011 | 11:58 PM
  #3782
Pro10noob's Avatar
Why do you need extra low arms??
Do you use to long springs?
The RS arms(new type now) are low enough to do the job
About the K-factory parts, the E4 Alum. 7075 Middle Shaft Mount (k2103)
isn't all that needed.
It is nice and bling bling and perhaps gets you car up to weight without adding some lead to it but it is also expensive.
Give me a hoaler about the bulkheads as you know i can get my hands on some red one for a lot less then the K-factory price
The 3 degrees alloy C-hubs might also be a option instead of the middle mount.
regards Roy
Pro10noob is offline
Old 06-10-2011 | 12:29 AM
  #3783
td-civ's Avatar
regards Roy
i have the 3 degrees alloy C-hubs they came with the car
the car is a fs with rs parts on it but when i got the car the right front lower arm was broke so i need one before i run it plus i want spare parts in case i brake them again lol
and for the red bulkheads i have nothing on the car that is red lol
i cant wait to run the car i so miss having a team magic e4
broken arm
almots done need to add my rx and get my new body and put on my new wheels
td-civ is offline
Old 06-10-2011 | 12:42 AM
  #3784
Pro10noob's Avatar
Front arms are all the same as far as i know.
Rear are different between the FS and RS if they are still the original arms.
Also the alloy part in the arms are gone with the new type.
Nice car by the looks of it
regards Roy
Old 06-10-2011 | 01:38 AM
  #3785
gearhead1962's Avatar
Hey that is a good looking car With the fs chassis I prefered the plastic bulkhead, a little more flex and what not. Sorry again about that arm man
Also I had flipped the steering crank around to get rid of bump steer. The guys at my track who where running the car more regularly than I was had real good results with that. Have fun with her and treat her right, she will be missed.
gearhead1962 is offline
Old 06-10-2011 | 10:25 AM
  #3786
td-civ's Avatar
thanks man i know you will be happy with the photon lol
the steering is set thatway becaue i hadto left the top deck up so my pack will fit so the steering links hit the deck so i changed it
ill change it after i test it if i have too
td-civ is offline
Old 06-10-2011 | 03:36 PM
  #3787
Slo_E4's Avatar
Super Moderator
I have a few sets of arms that I can spare for ya if you like. And also a set of front hubs, rear hubs, and caster blocks. I working on trying to get Pro10noob's car so help me help you.
There is a pic below... PM me for details if you are interested
Slo_E4 is offline
Old 06-10-2011 | 04:06 PM
  #3788
td-civ's Avatar
you got pm
td-civ is offline
Old 06-11-2011 | 02:01 AM
  #3789
Pro10noob's Avatar
Lol@Slo
In the sale (my car that is) are also new lower arms front and rear
regards Roy
Old 06-11-2011 | 02:18 PM
  #3790
YR4Dude's Avatar
I'll take those arms if you're willing to sell them to me. PM me your price and PP address.
YR4Dude is offline
Old 06-14-2011 | 04:59 AM
  #3791
Anybody have any news on the updated car ?? I keep looking at the TA06 but I still believe the E4 is a better design. I know in VTA and GT it's perfect. The tweaks in the upgraded version should make it a solid performer. Somebody give those folks at TM a kick in the ass so they don't drop the ball on this chassis.
Evoracer is offline
Old 06-14-2011 | 08:47 AM
  #3792
YR4Dude's Avatar
Originally Posted by Evoracer
.... I keep looking at the TA06 but I still believe the E4 is a better design.....
I feel the same way too. Just looking at TA06 in comparison with my JS, the JS looks way better. The laydown shocks is just a gimmick, there's a video of someone running the TA06 in Japan with the shocks in the normal position with a front shock tower. I also don't like the front belt rear gear tranny setup. That is so 1st gen RS4. Add to that it has a layshaft way up there when everyone has their layshaft down as low as possible. It just looks very clumsy and there is no comparison to E4.
Really the closest thing to the E4 is the old FSR car.
YR4Dude is offline
Old 06-14-2011 | 03:37 PM
  #3793
Don't get me wrong...I'm no Tamiya hater. In fact, it's the only NEW car I'd consider buying BUt....little things caught my attention like
1. No consideration for batteries that use banana plugs.
2. Wire routing looks even tougher than the E4. Anybody notice the pics of Satoshi's car where the battery wire is contacting the lower belt ??
3. Even the Tamiya junkies are questioning the layout of the IFS. It just seems wrong. The angle of the shock lever is odd.
4. Compared to the E4, the chassis extensions for the servo and esc seem quite wide. I guess thats why they had to angle them upwards.
Bottom line....the E4 is a really good chassis. Compared to many it's a breeze to work on and the layout just makes sense with little compromise. Little stuff already has fixes like that bulkhead at the left rear that makes motor movement a bit tight.
It seems to me that the changes to the newest version will make the car even better.
I think I'll stick with it. C'mon TM....give us your support.
Evoracer is offline
Old 06-14-2011 | 04:16 PM
  #3794
YR4Dude's Avatar
What really is needed is better parts support. Really the parts prices for TM is a bit outrageous. I can get Serpent parts for 25% less. Why should TM parts be so expensive. Its not like they're XRay. If their parts were as durable as XRay, I wouldn't mind the cost by they're not.
YR4Dude is offline
Old 06-14-2011 | 11:10 PM
  #3795
Pro10noob's Avatar
YR4Dude???
Ever tried them->http://www.rcmanufactory.com/
Velly cheap
regards Roy
