Tamiya mini cooper
#9016
Any tips on setting up an M02 (RWD version M01) chassis for tight indoor carpet?
I have all the option parts from Tamiya available plus a wide range of tires. The car spins out in corners (using a kit supplied silvercan with highest gearing) no matter what combination of tires I choose. I am using TA03 Tamiya shocks with kit supplied 30wt oil and tallest spacers and Tamiya on road tuned springs white at the front, kit springs at the back.
I have tried 60D mini slicks (with Tamiya hard sponge inserts) and the handling was worst. Changed to kit supplied radials M grip front normal rear (kit sponge inserts) and had horible oversteer, swapped them around and had horrible understeer.
Last I changed to HPI X pattern (RS4 mini pro inserts whatever they are, I can't remember) and still have horrible understeer (low speed) and tailspin if I throttle it.
I have also installed both front and rear swaybar kits.
I have about 4 deg total toe out on the front and 0 camber all around.
#9017
I have tried 60D mini slicks (with Tamiya hard sponge inserts) and the handling was worst. Changed to kit supplied radials M grip front normal rear (kit sponge inserts) and had horible oversteer, swpped them around and had horrible understeer.
Last I changed to HPI X pattern (RS4 mini pro inserts whatever they are, I can't rmember) and still have horrible understeer (low speed) and tailspin if I throttle it.
#9018
#9019
I use two hole pistants front and rear 35wt oil front and rear. And ofcourse sway bars. Keep ride hieght even front and rear. How much ride hieght you have doesn't really matter just as longests its even front to rear
#9020
diff
bearings in the gearbox
and my m8 makes milled aluminum parts so i have adjustable rear wishbones and adjustable front and rear shock towers
i run a hpi sport 27t can
and i need to order a few bits as my front wishbone snapped
but i will have 18t pinion and alloy front wishbones
my oil weight is 35 and the car is m03 old mini cooper shell
with th adjustable wishbone and shock towers it also enables me to run any kamtec shells so i was thinking mk1 golf or cosworth:P
so the spec you say is just tires?
anything on toe in or out or what oil to use
how bout anything like inserts for the tires?
at my club i race minis 1/10 and micro buggies such as the blaze
all the minis seem to be good on the track its just mine,
i am just here to get all the tips to get the edge on my dad as me and him are neck to neck every race
thanks
matt
#9022
M-03R Blue Limited Edition
Hi all,
I just wanted to let you know that i have a tamiya M-03R blue limited edition for sale. I rand this car only 2 race days and still looks like brand new.
The car also has Hotbodies blue aluminum competition shocks on.
here is the link for sale thread.
http://www.rctech.net/forum/r-c-item...ml#post5793819
Thank you!
Thank you!
#9024
Yet another in the seemingly endless lot of new 4WD Mini chassis to emerge from Asia.
This one is a conversion for the TA05 made by RC-SQUARE in Japan.
#9025
Hey tony, these questions are for you.
I have an old tamiya mini cooper body (came with new box stock m03) and it fits perfect.
Last year in September i bought another mini body. i just painted it for the first time a week ago. I put it on my m03 and the battery with cell mounts it bulges out the side panals. I put it on my m01 and the same. I compared both bodys. My old and new one side by side and the new body is WAY narrow... about half inch in the door area on both sides.
Is this a defected one? Or is my old M.C body just "broken in"? Im thinking of just making it a shelf queen.
i know youve painted more then one mini body have you ever had this problem????
Also whats your thoughts about 4wd m-chassis? What do YOU like better? Im thinking of getting one but i just LOVE FWD
#9026
No idea..... I know the ABC Mini bodies are a lot narrower in the centre section, but (assuming yours is a genuine Tamiya) I doubt there would have been any change in the Tamiya bodyshells.
As for 4WD Minis, most of us at rc-mini find them only mildly interesting. They're just a shrunken down Touring Car and have none of the quirks and foibles of a FWD Mini chassis.
I report on them, and I have a lot of them, but I have to say I'd be lucky to drive one once a year. They're just not that interesting to us.
#9027
Has anyone converted the M-03 to use machine hex screws? Or are the self tapping screws the only way to go?
#9028
Sure makes life easier to not deal wth philips head screws.
#9029
Ain't No Stopping A M03
#9030
I routinely replace most of the self tapping screws with machine screws. You should tap the screw holes part way or it gets very difficult tighren them all the way. Partially tapping makes it a lot easier. You can use a flanged tube for the shoulder screws in the suspension. Use a 3x15 for the servo mounting blocks. The extra length stiffens th servo mounts.
