Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-05-2009, 02:09 PM
  #8266
tony gray's Avatar
How about 2 photos...
tony gray is offline
Old 02-05-2009, 02:20 PM
  #8267
axle182's Avatar
Trader Rating: 18 (100%+)
EWW!! im all for new mini bodies but..... EWWW lol Maybe im old fashioned but the orignal fiat looks amazing, im not a fan of the new one tho
Cant wait to see how much the new HPI bodies will be. I think they will be the new standard. The datsun looks amazing, and im so happy to hear they are going for realism first! Yeah i know, the chrome bumpers etc will be killed in the first crash, but I love the realism!!!
axle182 is offline
Old 02-05-2009, 03:11 PM
  #8268
Skitee's Avatar
I like it, I will be picking one up as soon as it's available.
Skitee is offline
Old 02-05-2009, 04:17 PM
  #8269
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by tony gray
Pit Shimizu mini tyres available again soon, in 24, 27 and 30 compound. Don't ask when /where, we don't know yet.
But if they're as good as they used to be we can't wait.
Better than the Team Powers pre-mounts? That would definitely be amazing.
Jim
monkeyracing is offline
Old 02-06-2009, 09:05 AM
  #8270
Core Creations's Avatar
Trader Rating: 108 (100%+)
I see the potential...pardon the crude MS Paint
Core Creations is offline
Old 02-06-2009, 01:38 PM
  #8271
http://www.tamiya.com/japan/nurnberg/movie/m03.wmv
Masato is offline
Old 02-06-2009, 01:55 PM
  #8272
tony gray's Avatar
Masato-san that is SO cool!
Old 02-06-2009, 02:09 PM
  #8273
Which is cuter?? The minis or the japanese babes??
Ben.C is offline
Old 02-06-2009, 02:28 PM
  #8274
tony gray's Avatar
And...the videos up on the front page on rc-mini.net now..
Old 02-06-2009, 06:46 PM
  #8275
akura2's Avatar
Certainly it's bang on the money for M chassis size specs for both SWB and MWB.
And HPI are saying that they're doing a full range of bodyshells as well. Although the wider ones could be a problem. This could be interesting. With the Switch FWD and now this car, seems there is a big HPI M chassis push.
I just spoke to my friends at HPI and they said that the car in your post IS the new "mini" and that all the mini bodies will fit... the front shocks have two different mounting positions (vertical and laydown) and there will be at least SIX different body post setups for different bodies... the laydown front shocks will work great for the ABC bodies....
akura2 is offline
Old 02-06-2009, 07:19 PM
  #8276
Regional Moderator
Darkseid's Avatar
That body looks alot better in motion!
Darkseid is offline
Old 02-06-2009, 08:09 PM
  #8277
tony gray's Avatar
Close, but no cigar.. Its 1 of the 2 new Minis.
One being this one (The True Ten Cup Racer) , the other being the new FWD car (Called Switch) People (and even HPI people too) seem to be getting them confused all over the place!
Old 02-07-2009, 01:54 AM
  #8278
tony gray's Avatar
Well, if people were undecided about Tamiya's version of the Fiat 500, I think we'll all be united about this one from Team Atlas which has just been released mounted on their 4WD Beat chassis
Did someone leave it out in the sun? I think it's melted!
Or this weirdo Japan only car that I haven't been able to identify. Atlas call it the To-Pa
Looks fairly tough I suppose but I won't be rushing out to get one myself.
And finally this offering called the SK-LA.
I'm not sure what to say about this one but obviously the designers lost their french curve templates behind the sofa....
Old 02-07-2009, 07:31 AM
  #8279
Starteur's Avatar
Can I get those:
the adjustable ones from the M03R ( camber links)
whitout buying the blue bling-bling?
Or if I have to make a camber link that is adjustable with sway bar pieces,
will I be TCS legal?
Thanks guys
Starteur
Starteur is offline
Old 02-07-2009, 10:34 AM
  #8280
Originally Posted by Starteur
Can I get those:
Thanks guys
Starteur
They are easy to make and are TCS legal. At least my car passed tech at the Nationals.
Use two 5mm short adjuster #50797 and a 3x12 set screw. Thread the set screw into one coupler and then thread the other one on the exposed threads. I used 5mm ball nuts and a 3x12 mm set screw to mount them to the rear upright. Use a 3mm button head machine screw, 4x6mm flanged tube #50593 for the inner mounting.
The main advantage to doing this is that you can even out the camber on each side. Most of the Minis I've seen have more camber on the rt than on the left. The other big advantage is if you are running low ride ht at the rear, you can decrease the amount of camber so that you don't get the dreaded death groove with Tamiya 60d tires.
Granpa is offline
