Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-17-2008, 05:43 PM
  #7516
R/C Tech Elite Member
monkeyracing's Avatar
Originally Posted by SUNA
Where did you find that!?
"rcmart.com"
I order a lot of stuff out of Hong Kong and Singapore. It's regrettable that local hobby shops won't or can't compete. I do like to support local business, but if I'm getting better selection at half the price...sorry LHS.
Also, check out http://www.stellamodels.net/catalog/default.php and http://www.vellrip.com/store/home.asp
They're both good sources for mini parts, with good pricing.
Jim
monkeyracing is offline
Old 10-17-2008, 07:47 PM
  #7517
Trader Rating: 47 (100%+)
I am plannig on ordering Avid bearings for the M03M but have a question...what type is recommended? Rubber, metal, revolutions? Or a mixture per application ie) revolutions for hubs, metal for tranny, etc.
Correct?
8 - 5x10x4
4 - 5x11x4
2 - 5x8x2.5
Thanks in advance!
SUNA is offline
Old 10-19-2008, 09:28 PM
  #7518
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by cannon
We usually take about 8-10 guys from Australia. It is increasing each year. One of the best race events around. The Mini class will be interesting. Hopefully they separate the two classes of Mini. Apparently they have a good Mini following in Bangkok so the class should be good. And you live so close .. easy for you to get to.
yeah , we have racer form here going there for touring car races ...
edwintklee is offline
Old 10-19-2008, 09:42 PM
  #7519
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Hey guys,Just got my first mini.....
It came with a set of the Blue aluminum shocks.....what is the hot setup on these ???
It still had all the bushings in it so i put in the bearings.....also put in the Ball diff.......
the guy was running the shocks with #3 hole pistons .....2 red seals under the rears and 4 under the front pistons....dont know what weight oil....
do you shim all that slop out of the frontend?
any help would be app......
Thank's.....
Factory Seal is offline
Old 10-19-2008, 10:48 PM
  #7520
Most folks have found out that shimming up the slop makes the car handle worse...
stocker is offline
Old 10-19-2008, 10:56 PM
  #7521
Looking for advice on a steering servo. I think mine is slowing down, and it was never a fast servo to start with.
Can anyone offer any advice as to what would be a good, quick servo, but still priced within reason? As a way of offering reference, I'll say that a servo that costs more than $100 is not reasonable, especially for a mini.
Jim
Old 10-20-2008, 01:44 AM
  #7522
edwintklee's Avatar
http://www.rcmart.com/catalog/rc-tl0...th=595_744_707
wonders if this arm will help to reduce the mo3 traction roll problem...i notice mo3R will not roll as easy...even a very light lipo powered car....my current setting will only work with nimh, when use lipo it will flip almost at every corner.....also my sport tune its same speed as a sliver can any help on that too??
i am usingM03 + GTX with sport tune, and the other guy its using M03R + TEU101 esc with sliver can but i can seems to close the gap in between...
Old 10-20-2008, 01:54 AM
  #7523
Trader Rating: 28 (100%+)
I've tried them. They make 0% difference.
Plus you can't use the antiroll bar with them (takes a tuning option away)
Sports tuned motors can be very incosistent and they don't last very long now-a-days.
Cheers
Ashley Cobb is offline
Old 10-20-2008, 01:55 AM
  #7524
What is the difference from the stock arms? thanks!
stocker is offline
Old 10-20-2008, 01:57 AM
  #7525
cannon's Avatar
Trader Rating: 35 (100%+)
They are just one piece so maybe less flex but otherwise no advantage
cannon is offline
  #7526
They are lightweight arms. In theory there is less unsprung weight. In practise, it makes no appreciable differece
Old 10-20-2008, 02:07 AM
  #7527
caltek1's Avatar
Trader Rating: 38 (100%+)
Default Tech/Spice Mini Arms
edwintklee,
There are two versions of the spice arms. These arms are also marketed under the Tech racing name.
One version as shown in your link has the shock mounting point moulded into the arm, with no provision for attaching swaybars as Ashley has pointed out.
The second version has the front shock mounting point seperate which is attached to the arm by one screw and has the holes for attaching front and rear swaybars.
Presently here in Aust they are not legal to be used in club challenges, etc, as it is thought the one piece arms give a slight advantage to the suspension system by taking some of the slop out of the lower a arms. They are also more rigid.
CYA
Calvin.
caltek1 is offline
Old 10-20-2008, 04:49 AM
  #7528
pmc213's Avatar
Trader Rating: 21 (100%+)
Folks,
Can someone advise on whether I can use a different servo saver in a mini.
I bought a mini 2nd hand and it was missing some servo saver pieces and bought a kimbrough which is shorter (from ball stud to spline) than the tamiya part.
1. Will this make any difference? I am assuming it would impact on bump steer given the change in angle of the steering arms; and
2. If it is no good what is the best servo saver to get and part numbers if you have them.
Thanks for the help,
Paul
pmc213 is offline
Old 10-20-2008, 05:37 AM
  #7529
caltek1's Avatar
pmc213,
I use a large Kimborough servo saver and trim the outer edge, so that it does not hit the chassis. I mount the ball studs in the bottom row of holes and this negates the bump steer. A dremel will bring this down to size quickly.
The other way is to use a droop screw in the knuckle and then place washers to raise the height and then screw on a tamiya ball stud. Make sure you use blue loctite. I will post some pictures tomorrow.
The other option is to just use the standard mini servo saver and then place a second servo clip around the original servo saver to hold it together. The servo spring is taken from the Tamiya high torque servo saver set.
regards,
Calvin.
caltek1 is offline
Old 10-20-2008, 02:18 PM
  #7530
Correct?
8 - 5x10x4
4 - 5x11x4
2 - 5x8x2.5
Thanks in advance!
Anyone?
SUNA is offline
