Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 11-22-2018, 01:22 PM
  #29791
Not on my M03 as it makes it drive worse. I shim about 50% out on my M05v2 and my M07 has no play at all. Everybody is different though.
Mini35 is offline
Old 11-23-2018, 07:47 AM
  #29792
Originally Posted by Bennet80
Does anyone shim the car to take all the play out of the suspension, axles and steering?
I have. I saw a difference in transitions, but really nothing to write home about. Definitely nothing worth spending the couple hours of tweaking it took.
airbiscuit likes this.
Nerobro is offline
Old 11-30-2018, 07:01 PM
  #29793
i need to run some narrower rear hexes on my m05 due to a new body im running rubbing...
are there any tamiyas that run a 4 or 5 mm thick PLASTIC hex?
we have to run box stock so id rather not run alloy hexes and draw attention of the scrutineers.
Lunchie is offline
Old 12-01-2018, 01:13 PM
  #29794
damang999's Avatar
Trader Rating: 15 (100%+)
ah so you want to bend the rules to suit your new body!! pretty sure the m07 stock plastic are 5mm, thats what kit ones measure
gigaplex likes this.
damang999 is offline
Old 12-01-2018, 02:15 PM
  #29795
gigaplex's Avatar
Box stock means what came in the box. You're still breaking the rules by using a different hex even if it's plastic.
gigaplex is offline
Old 12-01-2018, 09:48 PM
  #29796
R/C Tech Elite Member
monkeyracing's Avatar
5mm plastic hex (kit) plus sandpaper, plus a muzzle for gigaplex so he won’t bust you, would seem to be an optimal solution.
monkeyracing is offline
Old 12-03-2018, 04:06 PM
  #29797
eR1c's Avatar
Ha, I was just thinking sand paper too. ...
I ran into the same thing w/ various bodies rubbing against the wheels in the M class. There were a a few bodies that seemed to work better than the others for this reason.
eR1c is offline
Old 12-03-2018, 08:50 PM
  #29798
A lot of Tamiya’s earlier mini shells, like their original Mini Cooper, were designed when Tamiya was selling the kits with 55mm tires. Pretty sure thy used 4mm hexes at one point, too. Some (thankfully few) aftermarket shells are based around a narrower track or 55s as well.
I’ve been running Blitz shells for several years now with 60d tires, 7mm hexes and a few extra mm of wheel spacers on both sides, as well.
eR1c likes this.
Old 12-06-2018, 02:42 AM
  #29799
does anyone have this motor? https://hobbyking.com/en_us/turnigy-...-approved.html
I have it on my m05 v2 pro and I used the 20t pinion and the 20T mounting holes and it seems to be a little too far away from the gears. So the gears doesn't mesh properly
I used a spare trackstar 4250kv sensorless brushless motor and it seems to mesh nicely.
novaris is offline
Old 12-06-2018, 07:21 AM
  #29800
CSeils's Avatar
Trader Rating: 54 (100%+)
Is there any performance difference in the SPEC #1016 S-Grip pre-made tire versus the build your own sets for TCS? Other then the color of the rims?
CSeils is offline
Old 12-14-2018, 05:12 PM
  #29801
tony gray's Avatar
So...this might be interesting...
tony gray is offline
Old 12-14-2018, 08:24 PM
  #29802
Looking at that and the MG EVO side by side, there’s not all that much different, but I’d still go for the 3Racing.
It doesn’t matter either way, however, as I’m trying to figure out where I put all my M03 parts at the moment.
Old 01-18-2019, 05:35 AM
  #29803
Hey everyone,
I'm having an old guy moment. I just got the Yeah Racing heat sink (Part number M05-013O2BU) for the M05, and I cannot figure out how to install the thing.
I have the M05V2 motor plate from Tamiya and though the Yeah Racing site says to use their mount, it looks almost identical to the Tamiya one.
Any help would be appreciated. Link of the part is below.
Linky
ErikO is offline
Old 01-18-2019, 10:30 AM
  #29804
Pretty sure you need the Yeah motor plate as the screws from the sink go down into the plate. The Tamiya heat sink bars fasten horizontally onto the Tamiya alloy motor plate.
Mini35 is offline
Old 03-26-2019, 05:41 PM
  #29805
Trader Rating: 43 (100%+)
what are the essential hop ups you need to make the M05 easy to drive? A group of guys I race with are pretty fast with their M05s I don't get it.... they have the same brushed setup and tires as me. But I know they have ball diffs and I have the stock gear diffs. Does the ball diff really makes a difference? I come from 2wd off road buggy so this is pretty new to me.... On road using ball diffs....usually when yiu have tons of traction in off road .. we use gear diffs.
Phillip F is offline
