Tamiya mini cooper
Hey all,
I'm still reading much of this post but I thought I'd post. First time (Tamiya M05) "Mini" owner - I have the standard Mini Cooper kit #58438 (which I believe is the V1 chassis given no drop adjustment and doesn't accept square lipo's. Haven't run it just yet (waiting on bearings, servo, shocks, steering parts, & motor), so I consider it mocked up (can't post pic's, but I have pictures in my album on here for those that want to see it). I'm pretty happy with how it went together, and ecstatic with how the body turned out (first time I ever touched an air brush, painted a clear body, etc.).
I've heard of people talking about using different suspension holes for the rear upper control arm (or camber link as it seems most people call it), but the rear of my chassis as well as the knuckles... err, uprights (I think it'll take a while for me to adjust to the terminology used here) don't have any alternate control arm.... camber link positions. This normal?
I do however have two positions on the chassis in the front, and it seems the upper position on the chassis is the normally used position for the upper control arm... Uhh, camber link. That is how I have mine set up.
But I am having problems with bump steer. I've played with the arm length and been playing with shims, and I just can't dial out the bump steer to a satisfactory level - it's either way too much or way too much. Is it possible I assembled something wrong, or have I overlooked something?
M05 Pro V.2 after installing Lightweight Aluminum Battery Holder and shorty lipo offset to the right to counterbalance the motor. Only secured with one piece of tape but still surprisingly secure:
I've been working on a fan mount. Can't quite get anything to fit with the motor wires sticking up out of the can. Made one with 55mm worth of spacers attached where the heat sink bars go and the fan vertically mounted right off the end cap. Looks neat, but it's a lot of material flapping around. Thinking about one as pictured above, but the damned wires get in the way. I'll figure something out eventually.
i know this has been asked (many times before), but in order to update my M05Pro to the V2, all i really need is the A-parts and the motor mount, correct?
I have the other parts that the V2 comes with - i just want the ability to run shorty lipos
please don't beat me too much
having a somewhat bad day at work
Hey all,
get a longer ball stud and like a 3mm or 4mm spacers to raise the outer steering end so its pretty much horizontal. I was told to do this on my M03 to remove the bump steer, so when i build my M05, i just did it as part of the build
295Likes
