Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 03-28-2016 | 03:06 PM
  #27151
eR1c's Avatar
Hey Antlockyer,
This may be obvious, but did you use the Tamiya pinion guide when you installed your pinion on your motor?
eR1c is offline
Old 03-28-2016 | 06:07 PM
  #27152
sakadachi's Avatar
Originally Posted by bertrandsv87
Gears do rattle a bit in the mini cars, and cutting off their contact edges at a 45 degree angle makes the rattling go away and frees up a few more watts......
I'll give this a shot next time, thanks.
sakadachi is offline
Old 03-28-2016 | 06:34 PM
  #27153
Do you do this to all the gears very curious how much you chamfer the edges. Any chance you have a pic Thanks
Rozzy is offline
Old 03-28-2016 | 07:28 PM
  #27154
(0000000000)'s Avatar
http://www.rcmart.com/yeah-racing-mg...Path=1293_1307
(0000000000) is offline
Old 03-29-2016 | 01:33 AM
  #27155
antlockyer's Avatar
Originally Posted by eR1c
Hey Antlockyer,
Long story.
When I built the kit I used it.
First race I had issues that sounded like loose pinion.
Guy and the track took the motor out for me and reinstalled the pinion using the guide.
Still didn't work, made weird sounds and had no drive.
If turned out that even using the guide it wasn't mating up properly.
I installed the pinion on the shaft with the gearbox apart so I could get it to exactly where it needed to be.
I'd done this a little wonky (it is right on the end of the shaft) so moved it down a mm and straightened it up.
antlockyer is offline
Old 03-29-2016 | 05:18 AM
  #27156
antlockyer's Avatar
Adjusting the camber should help w/ keeping your car straight and less twitchy. when i first setup my car I began w/ 3 degree negative in rear and 2 degree pos in front. Then worked towards neutral camber until car started to handle poorly ...for me the ideal camber turned out to be:
1.5 negative rear and about .5 pos front running long wheelbase.
What wheelbase are you running? I found that short wheelbase was much twitchier than long wheelbase. (never tried medium).
I'm using short at the moment which I'm about to change once I get my new shell painted. That will be medium. The two tracks I race at are very different, one being super tight, the other a lot faster. I think medium will be the best compromise.
As I have no adjusters I guess ride height is the only way I can adjust camber.
Old 03-29-2016 | 07:33 AM
  #27157
sakadachi's Avatar
I make my own camber rods as I am not bound by any track rules or regulations.
Quick example on my M-Four..
http://www.rctech.net/forum/members/...our-camber.jpg
M03...
http://www.rctech.net/forum/members/...amber-arms.jpg
and I can't find a picture of my M05 where I made the rear adjusters.. lol
Old 03-29-2016 | 08:13 AM
  #27158
antlockyer's Avatar
I'll have a look at the car later and see what I have in my box of bits.
Old 03-29-2016 | 09:03 AM
  #27159
All you need to make adjustable camber links is 5mm short balls, some short adjusters and some 8mm set screws. Consider adding shims between the ball cups so if you get bumped or hit a board, they are less likely to jump a thread. I found that 0.5mm shim will change the camber by roughly 0.5 degree if you are around 2 degrees of negative camber.
elecsual is offline
Old 03-29-2016 | 09:24 AM
  #27160
eR1c's Avatar
The other thing to adjust to remove twitchyness is the toe-in front and rear.
For the rear toe-in I don't remember what the default plastic hubs are set at, but try playing w/ after market hubs if you can.
Yeah, the medium wheelbase should feel a bit more stable. I ran the short wheelbase for an entire season, switched to long and was like dang ...what a difference!
eR1c is offline
Old 03-29-2016 | 09:26 AM
  #27161
eR1c's Avatar
As for cutting the gears, ...what I did and found to work really well was to use some 1000 grit sand paper and lightly sand off the hard edges. I did this to all the plastic gearing. Just do it a little, to take off the hard edge on each tooth. After, clean w/ soap and water, let dry then lightly coat w/ a very fine spray of silicone. -use very sparingly.
Others may have other suggestions..
eR1c is offline
Old 03-29-2016 | 10:53 AM
  #27162
AngryRog's Avatar
Let the rotor "tuning" begin... That is all.
AngryRog is offline
Old 03-29-2016 | 11:34 AM
  #27163
k_bojar's Avatar
Originally Posted by k_bojar
does anyone have a setup for a M06 on asphalt with the TCS tires?
thinking about trying one out this summer and wanted to find a decent starting point
anyone??
k_bojar is offline
Old 03-29-2016 | 11:57 AM
  #27164
M grips all around
Yellow front springs
Blue rear springs
Thin rear swaybar
Mount battery in rear position.
I found s grips to give slightly better traction, at the cost of replacing them much sooner.
Old 03-29-2016 | 01:58 PM
  #27165
monkeyracing's Avatar
R/C Tech Elite Member
One of my favourite pics. A classic.
monkeyracing is offline
