Tamiya mini cooper
for doing that
So I think the following disclaimer should apply
Do this mod at your own risk!
Yeah, but he was allowed to plug the hole after building the shocks. The guy asking is in Canada, the land that Tamiya forgot.
i was surprised how 'soft' the guys in Japan were running their M-chassis... i should have stuck to my original plan..
oh well, live and learn...
im certain they were drilling pistons too... if not oil weight down into the 25-30 range...
The moment I ran the 54000 with its tiny piston holes on my V2 I was like WTF, how are people actually liking these dampers?!
I swapped out to the cheapo 3 hole pistons and walla.
I've had decent results running a soft setup. My car is an M05 V2, running the following;
-3 Racing alloy dampers, 3 hole pistons and 35wt oil.
-Medium and soft springs, no anti roll bars.
This is also when using Ride inch up tyres, MC38 and SC32 front and rear.
considering i dont race carpet much (at all) but coming with the viewpoint of "when there is more grip you need a firmer setup" i hardly expected to see that many soft setups on the rug... let alone as soft as they were running them.
overall balance was a bit different that it felt on the local carpet track that i practiced on beforehand.
i was told that last year the majority were running a bit firmer (which is how i set my car up in preparation)
after walking thru the pits and talking to a few people i was surprised..
a good experience tho..
I must admit I was suprised when I heard about the same thing from TITC a couple of years ago. Many drivers going to a soft setup to help prevent traction roll, which flies in the face of conventional setup.
But come to think of it, who ever said mini was in any way conventional..?
The CA does a lot to help this, these days on carpet, we play a balancing act, by making as much front grip as possible to turn the car hard and fast, and using CA on the outside edge to not allow the tire to keep gripping once the car starts to lift the inside tires. I know you cant use CA at a TCS event, but a lot of people use less camber to let the tire roll off the tread in those situations.
295Likes
