Tamiya Ta06
#2446
No, I'm just using the stock gearing for everything at the moment.
I locked my rear gear diff with blue tack stuff before deciding on a rear spool.
Yeah, I think that front spool will give too much understeer. Too much understeer when I locked the front gear diff. Although it works for some rc drifters.
#2447
Yeah locking the front diff is no good for drift.
Fine under power and actually sideways, but no good when trying to swing the back end around and the inner tyre needs to be basically stationary as the outer takes a radius.
#2448
i saw this body on the tamiya website:
http://www.tamiyausa.com/items/radio...body-set-51170
so i looked for the tamiya 51170 item number on ebay, and found 1 for sale.
now it has arrived and it is missing the left window and has heat resistant tape against the inside left door
according to the seller this is the way the body is delivered by tamiya as its meant for internal combustion engine TC's, however on every picture i see from tamiya the body has a window and is advertised for TT-01, TA-04 and other TC's
its not even legal to drive a car without a window in the electric powered competitions here
so what happened here? do they make 2 versions under the same number 51170 or did someone modify the body for combustion engines and then put it on ebay?
thanks for any help
thanks for any help
#2449
they just make one body, and someone just modified it, or its from a rtr nitro car from tamiya and tamiya already did the modifications, but mine came with both mirrors, and had a hole already cut on to for the nitro engine, if there is no hole cut out, then its not from the rtr kit, and likely just modified
#2450
thanks for any help
thanks for any help
#2451
Main difference with the pro are the arms from trf418, the plastic parts are carbon reinforced, carbon damper stays and steel hex screws.
I got the titanium screws, but I have to say prob not with the price. Not sure how much a few grams of weight is worth.
The wheels are http://www.tamiyausa.com/items/radio...els-4pcs-84247 and the tires are tamiya medium narrow radials : http://www.tamiyausa.com/items/radio...al-tires-51023
Dish wheels or the more simple white ones are prob better (lighter) from a performance pov but I wanted nice looking wheels to go with my body I am going to try these next : http://www.tamiyausa.com/items/radio...els-2pcs-84357.
I have the brushed engine to start out in a stock series, it's my very first tc and I need to learn a lot.
I really don't like the servo mount in the car, it's awkward to work on and doesn't hold my sanwa servo very well. Does anyone have an alternative?
I drove the car for the first time on a large carpet track yesterday, it drove really nice and I had no major problems.
I tried the 23t and 26t pinion and it did feel a little slow. But maybe the stock silver engine can't go a lot faster. I also had no point of reference as the other cars on track where from a brushless series.
What gearing do others use/ advice?
If so, i was the guy who gave you the part for the servo saver.
Your car was indeed very slow, but the main reason to that is you we're running a Li-Fe battery while the rest of us use Li-Po batteries.
That gives a lot of difference in speed, for that reason you need to have a lower FDR.
At Vosselaar i would try to start with a 96T spur with a 40T pinion.
The spur and pinion you are using are the 06 module, the ones i recommend are the 04 module.
Although your car was running good, you had a little to much steering and you need more speed.
The car itself is great, i've got the PRO version with the 418 suspension mounted and by converting to this suspension the car became faster then before.
Next week i will bring my TT-02 to have more testing and then you can see the difference in speed.
#2452
Are you the guy that was running at a big belgian indoor track in Vosselaar?
i just got a 29T pinion 06 module, and i have a 31T with 66T spur on the way. if that isn't enough i will order some 04 module parts as 31T seems to be the biggest pinion that will fit.
i also got a better charger that will charge my LiFe batteries to 7,2V instead of 6,6V so that should help a little too.
And thanks again for helping me with the servo part!
#2453
thanks for any help
thanks for any help
Unfortunately there isn't a pic of the other side. If you called Tamiya USA and gave them the part number of the kit (43519) they could tell you if the body came precut. Good luck with it.
#2454
It looks like you may have one of there GP RTR body sets, or a body from this kit. http://www.tamiyausa.com/items/radio...-nismo-z-43519
thank you for the link i am trying to return the body now
#2457
It's definately worth the upgrade to your TA06.
#2458
that was me indeed
But in my opinion your better of with the 04 module gears, it allows you to have a better fine tune with the FDR.
I was just looking to your pictures and i saw that your dampers are mounted on the outer hole on the damper stay, you should mount them 2 holes more to the center.
That will make the car less responsive when you go into a corner.
#2459
If that doesn't give you the speed you want you can always buy a TB-03 spur, that's a 64T spur. (i think that's the smallest 06 module spur form tamiya you can use on a TA06 chassis).
module 04 seems to be hard to find online, the US 64p is about the same right?
#2460
If you need them i can give you some links where you can find them easily.
If you ever decide to participate at the belgian tamiya cup series you need those 04 module gears, cause the 64 pitch isn't allowed there.
Some people say that 64pitch is the same as 04 module, but i never tried to mix them so i'm unable to confirm that.
If you were running the dampers in those positions then you should try to mount a harder spring in the front and a softer one in the rear.
I'm Always running a blue one in front and red one at the rear.
