U.S. Vintage Trans-Am Racing >
Like Tree1Likes
Old 05-03-2008, 06:33 PM
  #961
chicagokenji's Avatar
Originally Posted by ChadRacing
If anyone is using a xray chassis
Understeering or oversteering?
Carpet, asphalt or concrete?
Lots of people are racing outdoors now.....
chicagokenji is offline
Old 05-03-2008, 08:28 PM
  #962
Grenade10's Avatar
Trader Rating: 40 (100%+)
If anyone is using a xray chassis... can you post your setup? I am having issues getting traction entering and exiting the corner. But have mid-corner traction
Thanx
Which X-Ray are you using? We have several here in Colorado, including myself.
Grenade10 is offline
Old 05-03-2008, 09:30 PM
  #963
BadSign's Avatar
Trader Rating: 15 (100%+)
We have a half dozen racers starting into the VTA this Friday at Indy Slots. Here's a shot of my Camaro- sans #'s and Vintage wheels/ tires (still waiting).
Attached Thumbnails U.S. Vintage Trans-Am Racing-usvta-camaro-004.jpg   U.S. Vintage Trans-Am Racing-usvta-camaro-001.jpg
BadSign is offline
Old 05-04-2008, 05:30 PM
  #964
ChadRacing's Avatar
I am using a Xray T1 Evo2. We are running on asphalt. Im loose in entry and exit but tight in the center of corner.
Quick Setup:
1.5 Camber all around
2 degrees toe rear
.5 degree toe front
30 weight oil , 2 piston front 4 piston rear, white springs front yellow rear
shocks are position on outside hole on arms and 2nd from the inner hole on towers
Ride height is 5mm
ChadRacing is offline
Old 05-04-2008, 06:17 PM
  #965
losi nut's Avatar
Grenade 10, I'm going to be using a FK05, have any set up suggestions? asphalt medium grip untreated, my first xray. Thanks
losi nut is offline
Old 05-04-2008, 07:15 PM
  #966
robk's Avatar
Trader Rating: 22 (100%+)
I like the body
robk is offline
Old 05-04-2008, 09:23 PM
  #967
Grenade10's Avatar
I'm running an T2, but another racer is using the FK05. I need to get a second car set up, so I'll write down the settings and post here. I'll also check with the other racer using the FK05 and see what his set up is. I have talked with him, and believe our set up is pretty similar.
Old 05-05-2008, 06:17 AM
  #968
dodgeboy's Avatar
I have 26mm and 31 mm HPI vintage rims and treaded tires in stock
At BOBS HOBBIES and CRAFTS
67 S. Broadway
Pitman NJ 08071
856 598 1777
dodgeboy is offline
Old 05-05-2008, 01:49 PM
  #969
robk's Avatar
Quick Setup:
2 degrees toe rear
.5 degree toe front
Ride height is 5mm
Put 3* of toe in the back, to start. Get your car stable and work from there.
robk is offline
Old 05-05-2008, 02:28 PM
  #970
ChadRacing's Avatar
ok cool thanks i will try that
Old 05-06-2008, 07:12 AM
  #971
IndyRC_Racer's Avatar
Here are some photos of the body I just painted. The stripes on top are paint. Had a bit of overspray in the front, but I figure that will get bashed in soon enough. Need to get it mounted and the wheels glued up so I can get a picture of the whole car!
Attached Thumbnails U.S. Vintage Trans-Am Racing-blue66-lf.jpg   U.S. Vintage Trans-Am Racing-blue66-rr.jpg   U.S. Vintage Trans-Am Racing-blue66-top.jpg
IndyRC_Racer is offline
Old 05-06-2008, 08:30 AM
  #972
egalsim's Avatar
Trader Rating: 44 (100%+)
That body is gorgeous. It's funny how simple paintjobs can look so much better than those so called "custom" paintjobs on the right body.
egalsim is offline
Old 05-06-2008, 10:41 AM
  #973
pejota's Avatar
WOW! Nice looking car!
How did you mask off the pinstripes? I've used actual pinstriping from auto zone as masking tape to pretty good effect.. same concept?
pejota is offline
Old 05-06-2008, 12:55 PM
  #974
I used Top Flite Monokote trim for the striping - purchased at my local Hobbytown USA. Here is a product link on Tower (http://www3.towerhobbies.com/cgi-bin...SM&C=QAE&V=TOP). This trim comes as a 5" x 36" sheet with decent color selection - including chrome, is very thin, will bend ok around simple curves, and has decent adhesion.
What I did was cut the trim with an Exacto knife into a 2" wide piece to make the center stripe and 1/16" wide pieces for the side stripes. I masked the body with the trim, sprayed blue, removed the trim - cleaned some over-spray with body wash, and sprayed white.
In hindsight I probably could have just used the white trim on the inside (or outside) of the body instead of paint as it looked fine before I removed it. I have used the trim before on my F201 black plastic wings and it sticks okay if not overly abused. You can heat it up with a hair dryer/heat gun and it is easier to bend around corners. It also can be cleaned easily with body wash as it is designed to withstand fuel exhaust from r/c airplanes.
Another use that I've seen for the trim is wheel dots on pan cars. I plan on buying some black trim and will use a stencil to make my own car numbers. I might also use some of the white trim to replace the HPI white number circles as they are bit too opaque for my taste....hope this info helps.
Old 05-06-2008, 02:59 PM
  #975
losi nut's Avatar
I used to used the chrome trim for my dish wheels on the t/c when I would debut a new body. no faster but looked cool. My 65 GT 350 body will be red with white Shelby stripes. Laterz
losi nut is offline
