U.S. Vintage Trans-Am Racing
#8058
Trader Rating: 32 (100%+)
http://www.ksmetals.com/retail.html
http://www.plastruct.com/
#8061
RPM sells some scale tailpipes as well. Might be worth a look. They are at the bottom of the page. http://www.rpmrcproducts.com/products/sedan/detail.htm
#8062
Tech Legend
Thanks for any help you can provide.
Also have the usual people sized scales, etc.
#8063
As far as your balance issues, if you have a tweak station, let the wheels hang off the back bar so the chassis is on the bar, and center the car on the rod. Don't let any part of the chassis touch the stationary front bar. It should fall one way or the other if it's not balanced, or it should at least tilt the level. Add lead until it stays centered.
This is assuming you don't have the Xray balancers, or IRS balance balls, or postal scales or something. The other thing you can try is string or floss at the center of the shock tower, and lift the car in the air.
#8065
Tech Legend
so any tips on the gluing then? Do I glue only the fronts, and if so, how high / much should I put on there and any recommended glue and gluing method?
I do have that second set of tires that is getting more worn, maybe I'll try it on that set.
thinking of using a slightly thicker glue then like an AKA tire glue, and using the end of a q-tip with the cotton removed to put it on.
#8066
#8067
#8068
glue me baby
i think that glueing the sidewalls is a good bet. i was leary at first but it works and i would recomend it to anyone...... and i have,all i did was a SMALL bead where the tire rounds into the sidewall..Didnt ruin my tires at all,,in fact i had to reglue them for the main...and it was about gone after the main
ive run the same setup at seven tracks and have only had to glue sidewalls once and that was at Trackside were the traction was crazy,we ran on it a week after the novak race. i mean my gym shoes were sticking to the track!!!!!
just my 2 cents jc
just my 2 cents jc
