Tamiya TRF416 / TRF416WE / TRF416X
#1141
ahh.. thanks sohlman
#1142
Anyone know the largest 48DP sur you can fit?
Thanks Alan
Thanks Alan
#1143
#1144
An angle on the front arms, backwards or forwards. If you use same same blocks, like D-D, you have 0 degree angle on the arms. If you use different size blocks, you get an angle on the arms, hence the word "arm sweep"
#1145
C hub & F ,R Upright weekend back stock !
#1146
i am lost abit here, wouldn't using different blocks affect the toe angle??
#1148
ok i understand a bit better now. so when does one use this arm sweep? what are the effects of it?
#1149
The effects are where things get cloudy for me. I've never actually tested to see the effects on the entry, middle and exit of a turn. It's my understanding that more arm sweep will make the car a little more aggressive entering a turn. Perhaps someone else on this thread can give more specifics
#1150
just to clarify, the reversible short arm is used both front and rear of the car right (or do we only change the front/rear)? i just ordered 2 sets to try out...
#1151
How are you guys gearing your TRF416 with the standard spur?
With a 19T orion V2 element
With a 23T Tamiya TZ
Thanks in advance!
Thanks in advance!
#1152
Hi,
i have some question.
Whats better with the TRF 416, normla Mazda 6 or Mazda Speed 6?
Does anybody tested it?
Surely i´m driving on carpet, high grip!
greetz Max
greetz Max
#1154
Best recommendation I can give is that you test both. You may have personal preferences, one likes this and another that....
#1155
