Tamiya TRF416 / TRF416WE / TRF416X
#392
your wrong
Need to look closer....
Top deck longer (with better fit for bigger lipos), Rear bulkhead is now split, F&R Bulkheads are now the same width apart, all chassis parts are mounted symetrically about the cars centre line. All these changes are aimed at improving the flex characteristics of the car.
Motor has been moved further back in the car to aid traction
New diff and centre pulleys (both bigger)
Improved diff (bigger rings, more balls, in-car adjustment easier)
Revised steering system
New (larger) hub bearings (1050 sized rather than 950).
Plus I'm sure numerous other improvements yet to be seen
Regards
Ed
Regards
Ed
#393
They made spool before for TRF415, if Tamiya did not release yet or release but with limited quantities for TRF416, as happened with MRE, then we should try with this company, they make a lot of cool stuff with high qualities.
Look, if we enquiry them to make many, they should sell us with cheaper price. But the problem is if they could understand the order, we should instruct them with detailed measurements. As i know they shouldn't understand so much about RC kinds, they are just metal manufacturers.
Well, let's just thinking about that.
#396
gentelmen
I got a few kits here(5)
post some pics tonight
let the good times begin..
#397
pictures will be sent to you by
me or rc-point or c.v hagen
till later
till later
#399
till later
#402
#403
kentech.
chassisplate 2.25mm
suspensionmouth are differend...but same screw distance
only thinner.
new orderingnumbers.
in the kit 1A/1XB/1B/1D
till later
chassisplate 2.25mm
only thinner.
till later
#404
Gizmo, is the aluminum air scoop included?
