Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-22-2008, 04:49 PM
  #1126
adamge's Avatar
Originally Posted by syndr0me
Intruder alert! Don't you have a battery bar to flatten out? :-D
hehe. I only have three packs, so it didn't take too long.
adamge is offline
Old 01-23-2008, 01:17 AM
  #1127
Default Evo arms??
A little question. I looked at the setup from Jilles etc.. from DHI cup and noticed that they use EVO arms front and rear?
Could somebody point me in the wright direction wich parts I must get?
Thanks!
delanobe is offline
Old 01-23-2008, 01:55 AM
  #1128
TryHard's Avatar
Originally Posted by Stein Tumert
The short suspension have the number 53928 (will fit on TRF416 / TRF415MS and higher / Evo5 and TA05 with reversible / TA05IFS)
info on the evo arms above
TryHard is offline
Old 01-23-2008, 02:31 AM
  #1129
Blueman Austria's Avatar
Hy there!
I posted the lines below in the Evo5 thread, but there nobody answerd, so i post it again here. Hope that one of you have experience with this.
TB EvolutionV post:
I read in the TRF416 thread that Victor Wilck setuped his 416 at the DHI Cup with a 0,5mm shimm under the rear block of the front suspension. That perform a little anti dive.
This works great with a spool and stronger motors i think???
But does it also make sense in Stock racing with oneway? Has anybody tried it out?
I usual run on tarmac 1mm shims under the blocks, and on carpet (high grip, and tecnical) without the spacers. But i havent tryed anti dive or kickup yet.
Greetings from Austria"[/FONT]
Blueman Austria is offline
Old 01-23-2008, 03:21 AM
  #1130
Ivans's Avatar
Ivans is offline
Old 01-23-2008, 03:30 AM
  #1131
Thanks for the info!
delanobe is offline
Old 01-23-2008, 03:54 AM
  #1132
last year, running on asfalt outdoor with medium grip and a 19T motor i experienced that using anit-dive or kickup wasn't my thing.
kickup was really bad as the car put all his weight on the front wheels when when slowing down for a corner with a one-way. this made the car really loose in the back. tried anti-dive too but this gave too little steering so i left them parallel to the deck.
when driving stock i dont think you brake that much. anti-dive, as said before here somewhere, makes your car more stable during braking as it transfers less weight to the front of the car. when driving stock you want an as high as possible corner speed because accelerating with a stock motor while having a nice straight-end speed dont go together...
now i have a question myself too, last year i set our new local track record with my awefull xray T2 . now i see that most of you guys at the DHI cup used the D-D blocks at the front. this is against what i noticed at my track. i used the narrowest possible front end to get as much corner speed as possible. whats the difference here?
later,
Mark
Markiempje is offline
Old 01-23-2008, 04:11 AM
  #1133
TryHard's Avatar
later,
Mark
The difference is the track surface I guess. Carpet will always naturally have more grip than asphalt, so hence less steering is required from the setups.
I always preferd running wider front blocks on the 415 on carpet, and it seems to be the same with the 416. Just seems to make the front end calmer, and easier to drive hard.
Outdoors, narrower seems to be the way too go, as I personally have always found that you need to gain steering outdoors, and narrowing the front end helps that (as does adding arm sweep).
Obviously, you need to get your car set for your track for best results, if you feel narrower is best, then go with it
HIH
Ed
TryHard is offline
Old 01-23-2008, 04:21 AM
  #1134
later,
Mark
THX for the Info.
Greetings Blueman
  #1135
cant wait to get my 416!!!!!
Old 01-23-2008, 04:42 AM
  #1136
fastolfart's Avatar
Jilles, I look forward to running into at the TITC. Even though I am only running the 23t class, would you mind if I pick brains when you have some spare time.
You may remember, we shared a cab with Scotty one night last year going back to the hotel, I was the old bugger.
fastolfart is offline
Old 01-23-2008, 05:43 AM
  #1137
RocketRacer's Avatar
Ed, what is arm sweep? what's it effect on the car?
RocketRacer is offline
Old 01-23-2008, 05:50 AM
  #1138
<STU> Esq.'s Avatar
Default chasis prep
I have seen in this thread some people mention 416 chasis prep - sanding the edges and then sealing with a glue.
I have a 416 coming in the post, however have only had tub chasis models previously
Could someone please elaborate on the purpose of and detail of this process? Also which specific glue to use?
Thanks guys
<STU> Esq. is offline
Old 01-23-2008, 05:59 AM
  #1139
sohlman's Avatar
Trader Rating: 92 (100%+)
Simply, it strengthens the chassis. Also smooths the edges so not to catch on your racing surface.
Check out this thread:
http://www.rctech.net/forum/showthread.php?t=98346
sohlman is offline
Old 01-23-2008, 06:14 AM
  #1140
TryHard's Avatar
Actually, not quite correct.
Due to the cutting processes used in making the plates, the edges of the chassis are actually exposed carbon fibre (hence the slightly dull finish). When you run some ca round the edges, your sealing off the exposed strands of carbon, meaning that you reduce the risk of the chassis delaminating.
As most of the plates are UD carbon (the upper and lower plys a wovens, internally the plates are UD's at 0 and 90 orientation), any exposed edges is BAD, as UD's are simply not as resistant to impacts as woven fabric (there's nothing holding the fibres together bar the resin), so split apart easily.
HiH
Ed
TryHard is offline
