Tamiya TRF416 / TRF416WE / TRF416X
#8641
I haven't tested it yet...hopefully by today. The thickness is 2mm. I have few points to highlight here when using this chassis.
1) The 'L' shape weight (front) will touch the front steering post if you set the batt at the most inward position. So you can only use middle and outer position.
2) There are 2 positions for the batt Forward like 416WE and Rear 416X.....again the 'L' shape weight only allow you to use the rear position coz the steering system will touch the 'L' weight when putting left steering (you can't get full left steering)
3) I haven't weight my car yet but when I tried to balance it, its too heavy at the batt side. I wish Exotek would make the 'L' shape weight in thin pieces ie 5-10grams each so I can just add or remove it accordingly.
Other than that I think I m happy with the quality of this Exotek 416XL chassis and hope it will handle better than the ori one.
2. Even with all the grinding, you can't use the forward batt position.
3. The reason why I used the inner most batt position is that the car just balanced better there. the 60g weight that the L shaped holders give is a bit much. I think the car handles better with the weight as close to the center line as possible.
#8642
#8643
#8644
I managed to test my car today with the Exotek conversion....All the set up was the same as i ran with the original chassis....Tyre used was Much More 32....The most noticeable handling improvement that I noticed was I have tons of grips...before this my car was a little bit twitchy on the rear and the steering was never the same between right and left input...usually the left input was more sensitive making it break loose (I have tried a lot of things BUT its still there...Note: My old 416WE had this problem too)....Today all the problems that I had was gone...i can make aggressive steering input and still did not break the rear loose....I m really satisfied with this Exotek chassis conversion....Yet I haven't fully balance weight the car (still batt side heavy).....
I have new 25% lighter weights coming in later this week. PM me if you want to switch to these
THX, M
#8645
This might seem like a silly question, but what problem are you trying to solve by moving to these other chassis (Exotek, smokem, etc...)?
I have a 416WE and a 416X and not sure what I am missing. The cars seem to work pretty well with the stock chassis' on them. Why anyone would move away from the quality of Tamiya is beyond me. LIPO's fit in my car great...just a little bracket (Which took about 1 minute to build) for the neg. battery connector and battery works just great.
What am I missing?
What am I missing?
#8646
What am I missing?
What am I missing?
#8647
I found the Exotek chassis much too stuck on medium-grip carpet. The car was very planted, and I struggled to free it up. Lap times suffered as a result. I put the 2.5mm chassis on from the original car and it was much quicker. I'm not sure the 2mm is the right choice for carpet.
That said, with the belts flipped and the car properly balanced, I definitely felt like the handling characteristics were improved.
All in all, I'm VERY glad to see companies like Exotek support Tamiya, and I hope they continue to do so. This is the chassis I would run outside or in lower traction for sure. For higher grip, I'd have liked something closer to the stock thickness, or even 2.5 to try out.
#8648
#8649
What am I missing?
What am I missing?
#8650
What problem do you have w/ the intellect 5600? Just curious, as im looking at getting some. I currently have the IP 5000 30Cs, and they fit fine, and the case should be the same size since they are both ROAR legal..
#8651
I have IP5600 mAh 50C batts... they do fit fine in an original 416X chassis.
#8652
#8654
Length: 139mm
Width: 47mm
Height: 25.1mm
From the ROAR rulebook. It wouldnt make sense to have a smaller case than that, since that would mean less performance from the pack.
#8655
