Tamiya TRF416 / TRF416WE / TRF416X
#6707
The weight might go that low....wow....so much for 5 cell slowing the cars down....now lighter weight and lipo voltage......we might need bodies with more downforce
#6709
Hi,
Searching for some 416 WE set up sheet:
Carpet hight grip
LIPO
Rubber 32°
Stock motor 10.5 or 13.5
if you have that...
Thx
Carpet hight grip
LIPO
Rubber 32°
if you have that...
Thx
#6714
It is supposed to make the rear roll more since the weight of the diff is now slightly higher.
#6715
#6716
Nice write-up Ed! I found the same thing a couple of months ago when I managed to get hold of 4 mini scales. I had to drop 100 grams in weight after moving to a different state with different rules. I found the car to be slightly unbalanced after adding weight in front and behind the battery to reach 1425g. So if you are running less than that, then offsetting the battery is the way to go.
In time, we could be using saddle packs again, just like we did a decade ago. Now where is my Pro2...
#6717
#6718
Just a question on the split suspension blocks
Are you running them on both the FF and FR , RF and RR or only on one of them?
#6720
cheers
