Tamiya TRF416 / TRF416WE / TRF416X
#6691
I didn't keep the package that the 46s came in, I actually picked up a package that had 46 steel axles, 42 aluminum axles, the pins, float pins, setscrews and outdrives, since all my stuff was pretty worn out anyway. I don't think the outdrives are the exact replacements, but would work in a pinch and was chaeper than buying each piece seperately.............just sucks I don't have the number, got it from Ampdraw though.
#6694
Ah, I'm just disappointed I didn't drive better, especially in 13.5. I spent a lot of time at the track this past year. I realized more than anything, I just need more time to get consistent at a layout. It seems like there's so many guys that can throw their cars down and be as fast as they're going to get within a pack or two. I'm not sure how to practice that other than attend more big races, but that's quite a task.
I'm pleased with how things went in 17.5, though it's kind of a miracle considering the attitudes shown by some folks on the track. It's unfortunate, it really left me feeling pretty bummed the whole week.
#6695
Syndrome, I know what your saying. I myself spent several weeks prior to the race practicing, problem was, practicing the wrong way, just enforcing my same bad habits, and not getting any faster. Once I realized it, I really never got a good way of fixing it, but went with a different attitude. I was pretty happy with my final finish, after all how many times do you get a chance to play with your rc car for 5 days straight. What you pick up on is invaluable, the people you meet, are mostly pretty neat. Stuff like this can never be replecated. Remember its still just a hobby, there is only one winner and a lot of runner ups, its not a that big a deal. You had a good run, cherish it, it may the last high point of your rc racing career.
#6697
#6698
has anyone tried mounting a saddle pack in this car?
half between the motor and servo, half on the other side with the rx and esc. Just wondering if anyone has tried it
I was thinking it might balance out the car if the saddle pack fit under the top deack and if the belts were flipped so the pack could be mounted as far to the right as possible
#6699
#6702
Ive seen it done in a cyclone, looked neat, and had perfect L to R balance without trays and lead.
#6703
If your going to run a front diff you can get away with the 42mm axles, usually only run the 46mm axles when using a spool as the short axle seems to break the nylon spool cups, (pin out to far in the cup), since the diff would use pin cushions it shouldn't be a problem. Soory, no idea about where to get the parts, maybe rcmarket, but shipping is expensive for a small order like that. Try Ampdraw, in the US, they have a lot of Tamiya parts too.
#6705
Evening all...
So after part of my conversation with Randy was over setting up a car for lower LiPo weight (1350g is rumoured for BRCA/EFRA), so here we go... no phaffing with a scales or stuff, just a MIP tweak board.
First up, I set the car up with tie-rods instead of shocks (set equal L-R, and on the ends to give the right ride height) so I can get the weight balance sorted. Technically, this is setting the FR/RL and FL/RR cross-weight... but does the trick.
First two pic's show thats it's equal side to side when using the solid links instead of shocks. This is with the cells hanging over the edge the amount in the forth pic. I did try it with the cells in the usual slots, and suprise suprise, the weight was well off to the motor side
Next two pics are with it with shocks on... as you can see, spot on. Only change I had to make was one full turn on the RL shock collar. Supports the thinking that this is the heaviest side... so any extra lead I need to put on the car to get too 1350g (and I will need too, I'm pretty sure... got to 1400g with 60g of lead and a heavy motor fan recently!) will be going behind the cells to help, probably on the outside.
Some things to note... Cells can be tapped in happily using current slot, without obscuring the negative terminal...just! It's a little wobbly in the car atm, but I'm going to make up some light weight carbon locators for the bottom of the cells to hold them in place better
Also, with the cells out so far its now possible to access the bottom motor screw without removing the cells
So there we go, thats what I'll be running...
HiH
Ed
HiH
Ed
