Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 02-14-2010, 07:22 PM
  #8206
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by M-Technic
Tamiyas laid it down in Florida last night. My 416WE TQ'd and won 17.5, while my friend's 416X laid down the fastest lap of the night in 13.5, and another friend TQ'd and won RCGT with a 416WE.
That's awesome, congrats!
Randy Caster is offline
Old 02-14-2010, 08:03 PM
  #8207
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Randy, question:
Running saturday, in the slow twisty stuff it seemed like it pushed a bit on entry, and the middle of the corner. Anything you see in the setup blatantly wrong? The track is small, and very high bite (indoor) asphalt. Droop is travel over ride height. I was thinking maybe a D block in the rear, and put some camber gain back in (3.5 or 3mm)?
File Type: pdf
geeunit1014 is offline
Old 02-14-2010, 08:07 PM
  #8208
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by geeunit1014
Randy, question:
I'm not Randy but here's my two cents:
I would try running white springs up front, and/or remove the .5mm shims from the wheels. I would probably switch to the D block in the rear either way.
M-Technic is offline
Old 02-14-2010, 08:53 PM
  #8209
I had whites on it, but it felt better w/ blues, the softer springs had a little more front traction in the slow corners. I also have the screw taken out of the brace on for the steering rack in the top plate for more front flex. I thought about narrowing the car too, but never got to try it
Old 02-14-2010, 11:43 PM
  #8210
TryHard's Avatar
Something else to try, rather than a D on the back, is try an X on the front. Same amount of Toe, but makes the car a bit wider. Narrowing the car at the (I found) makes the car push more mid to exit, as it give more rear grip (and more reaction).
Elliott Harper was testing the same thing this weekend, and came to the same conclusion
HiH
Ed
TryHard is offline
Old 02-15-2010, 12:04 AM
  #8211
Originally Posted by artwork
My car does the exact same thing when the servo saver is done. Best way to check is turn the car on and push on the servo arm, if it moves really easily then it is time for a new one.
I've tried a few different servo savers on there so I m going to rule out the servo saver.
Please please please let it be a faulty front one way...
rnd_tang is offline
Old 02-15-2010, 06:18 AM
  #8212
someone who has a good basic setup for a 416X car? I am thinking of those accessories that come with the car out of the box
Zooberg is offline
Old 02-15-2010, 11:04 AM
  #8213
HiH
Ed
Hmm, interesting. Something else to try The car is currently good on power, but understeers offpower, so thats what im trying to find
Old 02-15-2010, 11:44 AM
  #8214
M-Technic's Avatar
I can't imagine needing blues and the screw removed on high grip carpet. Last time I ran on carpet with whites up front and the screw in the steering my car was oversteering like mad until I lowered the rear roll centers (AND raised the front roll center).
Old 02-15-2010, 12:23 PM
  #8215
Its not carpet, its asphalt.
Old 02-15-2010, 12:55 PM
  #8216
M-Technic's Avatar
Sorry, I'm not sure why I assumed it was carpet. In any case, I still run whites on med/high grip asphalt. But I can see instances where you'd use blues on asphalt.
Old 02-15-2010, 02:49 PM
  #8217
Joey4875's Avatar
HiH
Ed
Was he running xe in the rear front and x on the rear back?
Joey4875 is offline
Old 02-15-2010, 11:56 PM
  #8218
TryHard's Avatar
Nope, running 1X/1E. Same toe in as 1XA/1D, but moves the pin position out a little, and makes the rear a little wider with the same axle shims.
HiH
Ed
TryHard is offline
Old 02-16-2010, 04:22 AM
  #8219
kschu's Avatar
Trader Rating: 16 (100%+)
Randy, question:
i think u should try remove 1.0mm shim below the rf & rr suspension block...
kschu is offline
Old 02-16-2010, 06:17 AM
  #8220
M-Technic's Avatar
That could make it push more, lowering the rear roll center will increase the rear traction.
