Tamiya TRF416 / TRF416WE / TRF416X
#5011
Also, the proportion of the lengths of the front and rear short arms are different when comparing the original LW arms to the Evo V short LW arms. The front short arms are made shorter than how the original LW arms were proportioned.
#5012
hey guys ran my 416 for the first time yesterday and man it was solid, i did make changes and i think it helped...
front kick up 2mm
and a weight balanced lipo. (duh)
as far as im concerned i think the box set up is tops... im going to stick with it... the next area that i would like to consentrate on is the FLEX!! this was my major problem yesterday...
do you know what i could do to remove some flex from the chassis? any help would be appreciated.. ANY
thanks guys.
front kick up 2mm
thanks guys.
#5013
anyone
#5014
#5015
thanks man.
#5016
front kick up 2mm
thanks guys.
front kick up 2mm
thanks guys.
#5017
front kick up 2mm
front kick up 2mm
#5018
I'm loving my 416WE the more I drive it It does flex quite a bit but I know it supposed too and it helps a ton for traction. Even when the traction went away yesterday at our local track, I was able to control it with ease. i just got to hyper driving it and made some mistakes.
#5022
the letters go in reverse from 1XC I think is the narowest . from each consecutive wider block adds a half degree of toe.
1XB, 1XA, 1X, 1A, 1B, 1C, 1D, 1E and now theres a 1F.
1XB + 1D = 3 degrees
#5023
yes its the box WE set up, with a couple of changes, ..... i have some development going on the car and will report on the changes on tuesday next week..
do we know of any after market reseller with a foam bottom deck..
#5024
Hi Sage. I had the same problem with my 416. I've put on a center bulkhead and it took away alot of flex. Anderton
//rcmarket.com.hk/product_info.php?cPath=51_98_120_176&products_id=3 344
#5025
ok cool. where does the center bulk head go? doesnt the car come with one? im a little confused..
