Tamiya TRF416 / TRF416WE / TRF416X
#4861
#4862
#4863
OOhhhhhh... yup.. those look perty sweet!
#4864
Yay, more blue bling
Anyway, looking at Marc's car, noted some interesting setup bits... Looks like he's running a shorter than usual front wheelbase (looks like a 1mm spacer behind the arm), and using the non-WE chassis (batts are further back).
Also looks like he might have more than 5mm worth of ackerman spacers, but I can't be sure... the links are quite straight, but that could be a result of the shorter wheelbase.
Ed
Ed
#4865
Ed
Ed
cant really tell the chassis bit .. Good eye Ed!
#4867
Ed
Ed
#4868
Suspended
Anybody else noticed on mark's car
That he is running the rear left shock one hole more upright than the rear right shock.
Now that is an interesting setup!
#4871
Does anybody know if any of Marc Rheinard's 416 "World Edition" set-ups exist?
#4872
hye chaps i need a foam asphalt setup, i'm buliding my car this week and would like to start off by getting the basic idea, could any on tell me what i would need to do/buy to get the car ready to compete? i know its more of a rubber car, but i'm sure i can make it work on the tar...
thanks in advance for the detailied replies, i will be running a tekin R1 pro with a tekin 3.5T sensorless motor! so it should be pretty quick...
super quick. its all about handeling...
#4873
In simply terms;
Shorten front = Weight Forward, shorter wheelbase
Lengthen rear = Weight forward, longer wheelbase
Lengthen Front = Weight back, longer wheelbase
Shortern rear = Weight back, shorter wheelbase
I guess he was after more front end, and a bit quicker mid corner rotation..
As for the top deck Q... nope, seems like the WE deck (or a two piece with a cut rear brace as in the case of young Yannic's car) is the top deck of choice, regardless of surface...
Damm good spot on the shock setup too... I wonder if it's just a picture goof (rushing to get it looking nice for pics), or if it's actually been run like that... wouldn't be the first time I've heard of an asymetric setup
Ed
#4874
Not sure if this has been shown before, but for those who don't like tape....
TRF416 Lower Deck - (For Stick Type Battery)
Ed
Ed
#4875
Ok i have been messing around with my car a bit, and in regards more specifically to this WE chassis than every car, what is the effect of having more ackermann on the steering links? By more, I should say more angled versus less which would be straighter links.
Also, has anyone used the 416/TB03D aluminum rear uprights? Is it anything more than some more unsprung weight in reality?
