Tamiya TRF416 / TRF416WE / TRF416X
#4981
some 416WE upper deck arrive again !
#4984
#4985
I don't have the WE, but on my 416 with short arms, I run 42mm Ti bones in the rear and 46mm steel bones up front. In the rear I run either 1XA/1E block or 1A/1E blocks (pending on surface/track/motor). Up front I run 1C/1C.
#4986
Hello,
finally the Difftools made by WAS-Racing (one of the sponsors of the TRF World Racing Team Drivers) arrived. They should be used, when setting up a new diff (or setting an old diff). Best results are achieved with sandpaper (#2000). From now the Difftool will be available at several dealers. Please see the pictures:
#4987
Hello,
#4988
Hello,
#4989
#4991
What it does is hold your drive ring while you polish it . So it is for all intensive pourposes a waste of time. All you really need is the diff half with out the bearing race on it. use figure eight and circular motions while sandinf with like 600 or 800 grit wet dry sand paper. Then build your diff.... Belisima!
#4992
#4993
Hello,
#4994
I highly recomend sanding atleast the side of the drive ring that makes contact with the diff balls.
This provides a smoother and flatter surface for the diff balls to roll on. It makes your diff more efficient , it doesnt have to be as tight to have the same feel on the track. Only one side is necessary but do both rings. Try it at home and believe your eyes... and fingers!
#4995
I did .. read it again. The whole thing this time.
