Alex Racing Barracuda R2 & R3
Is there a good setup for an R3 on asphalt outdoors, modified racing, using two normal diffs, i.e. front and rear. Just to have other ideas
Will be working on such a setup too, and will post it here once the cuda is handling great
Bling bling, KO pimped cuda. The tape on the reciever is holding the cap away from the shaft, i wasnt going to risk not fastening it down as theres only a few mm between the two.
Tech Legend
Trader Rating: 51 (100%+)
RcMonk your Cuda was almost silent running on the track last night. It was so quite I had to see if you had a belt setup on it or not. Mine was never that quite. No one would ever know you had a shaft car.
Hey guys...one issue I had last week...
I took the rubber tires off the car to put foams on, and on the front and rear, the 28mm foams rubbed the ball links... do you have to run the low profile hubs front and rear in order to run foams??
R
R
Cool!! Sometimes you can't really tell if your car is quiet or not from the drivers stand plus a whole bunch of other cars buzzing around. Yeah, I cleaned all the gears and the whole drivetrain before heading to the race. Too bad I wasn't as fast as I wanted to be.
@RCMonk: Did you received the outdrives before the weekend? Did you tested them?
Tech Legend
Any ideas on my foam clearance probs guys?? I need to set up two more cars for the Tempe carpet track, but only had the one set of low profile hubs. I'm thinking if I change those 'shock end' style tierod ends to the ball cup style, they might clean... Any ideas?
Thanks!
R
Thanks!
R
Thanks!
R
Thanks!
R
-Dave
I guess I'm confusef as to why someone would manufacture a car that you can run foam tires on out of the box...
I guess if I don't have any other choice I'll have to buy two sets... anyone have a spare set or two they'd be willing to lose?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
-Dave
Tech Legend
Thanks!!
Thanks!!
In Japan where the car comes from they run rubber tires so clearance is never a problem.
Tech Legend
Originally posted by JDM_DOHC_SiR
...Rubber tires for life
How do rubbers work on Ozite??
Can you keep up with the foam guys?
R
R
