Alex Racing Barracuda R2 & R3
I got a few PMs and there are more orders then I tought.
Just for info:
I sell only the outdrives without the gear, washers and those stuff.
And I have one question. Do you want to use your old washers or do you want to use "my" new washers.
cya
Chris
Just for info:
cya
Chris
Just for info:
cya
Chris
Just for info:
cya
Chris
Later
Claus
I just sent you a PM. These "new" washers you are referring to, are these the thrust washers or diff rings ?
Just for info:
cya
Chris
Just for info:
cya
Chris
The diff rings. They are lasered out of spring steel. The steel is not polished but hardened. And they are not cheap. Around 8$ the pair without the washers. They have a longer life time then the standard ones.
And one tip for the outdrives:
Use them with the Xray blades. They are a little bit too big but they work.
The new rings would be cool but might be hard to get down the road. I would just rather use the stock diff rings. Any pics of the diff rings that you are using ? Maybe a pic of the diff disasselmbled ?
Ok, a few more pics.
You can see what happens when you forget to use the second diff ring.
http://www.rcpics.net/view_single.php?medid=45621
http://www.rcpics.net/view_single.php?medid=45620
http://www.rcpics.net/view_single.php?medid=45618
http://www.rcpics.net/view_single.php?medid=45617
I have around 100 diff rings. That should be enough for me.
Can't see the pics. Something must be up with the hosting server.
Tech Legend
Trader Rating: 51 (100%+)
Yeah, I can drive the car for the rest of my life.
thanks
-Dave
I wrote that to all guys who sent me a PM. I hope that I meet the guy with the CNC today. I tell you the price as fast as I can.
I talked to the the guy and he said that he will phone me tomorrow. He had a lot to do and he had to calculate the price.
I have another solution for the diff ring problem. I tested the first version of the outdrives with standard rings from the industrie. I donīt know how they are called in English but in german they are called "Passscheibe". (Yeah, three "s") You can get 100 pieces of this rings for around 5 here in Germany.
Just one problem: With ceramic diff balls they work for around 10-20 runs. With carbide balls they work only for 1-3 runs. I did not tested them with the standard balls. Just think about that. I can offer both kinds of rings.
Diff Screw replacement...
Just a quick question....
Do you guys know, will the Team Associate (TC3) Diff Screw can be fit on the R3 ball diff. ??
cheers
cheers
Wyd,
How did you get the pictures to display? I can't get them to work
