Alex Racing Barracuda R2 & R3
Originally posted by Crashmaster
The rest of my setup:
Front:
60Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Shocks on outer most hole, inner hole on bottom
Rear:
40Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Shocks one whole down, outer most on the bottom
Cheers
Dan
Front:
60Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Rear:
40Wt oil
2 no. pistons
-1.5 camber
1.4x6 springs
Cheers
Dan
u will get more steering.
Originally posted by stjerno
Hi Dan,
Your right about the dampers .. if you lay down the rear a little more you get more steering.
When do you need more steering ? Going in/out or mid corner og all the way around ?
Claus -
Hi Dan,
Claus -
Its mostly getting the front end into the corner where I'm struggling. Originally I thought that when you dropped the front shcoks down it would give more steering (effectively softening the springs I believe), but obviously I was proved wrong
Cheers
Dan
Originally posted by TC3
if u are running on asphalt, u should use lighter oil in front.
Cheers
Dan
Thanks for the reply stjerno
Cheers
Dan
Cheers
Dan
Don't know the caster blocks on the Triox but you should try the 3 deg blocks in front and maybe the 3 deg rear toe hubs to as they will give less gripp in the rear = more front grip
And as TC3 writes .. lighter oil in front.
Going in you also migt want to go 0,5mm lower rideheight in front than in the rear, this will move the weight to the front of the car and give more steering.
Cheers
Dan
Cheers stjerno, I'll give that ago on Sunday I wonder how much I'll damage on the carpet
Cheers
Dan
Cheers
Dan
Some good advice for indoore racing .. if your track has wooden rails around the track .. DON'T use the hards hubs ect.. go with the plastic stuff .. This is what I call experience
Pic of my car attached, hope its still in one piece after the weekend.....
Cheers
Dan
Quick question TC3, are you still running the Triox??
Cheers
Dan
Cheers
Dan
the car is getting faster every weekend
now i have to find a good carpet setup..
Originally posted by JDM_DOHC_SiR
Yutaka Takizawa
Ryota Takahashi
Hideo Kitazawa
Yutaka Takizawa
Ryota Takahashi
Hideo Kitazawa
yes !
yes !
Cheers
Dan
Tech Legend
Trader Rating: 51 (100%+)
Anyone have more pics of the Cuda's running at the Worlds!!!! Tires of seeing the same old cars getting in the pics. They do have a nice one of the Cuda with the body on going around the track.
this is one pic of the Cuda with the body on going around the track
-Dave
http://www.fseara.org/gallery/album53/kitazawa?full=1
like hell thats their actually car...its only just been built hasn't even been run (no dirt or anything on it) and they would most likely have the new hubs on wouldn't they
