Yokomo MR-4TC SD
Originally posted by highwayman
hi... just to clarify, im using the CGM and the manual says to use the upper hole of the front C-hub and the lower hole of the rear uprights... or did i get it wrong?
anyway, i tried using both upper holes on the front and rear, but i have difficulty getting the droop i want with the proper ride height.
any comments would be gladly appreciated. thanks - jason
For the problem of setting droop, are your dampers too short?
Dear all, I also tried raising the roll centre by putting collars under all a-arms holders... (remember those unused collars came from the box?! )
The feeling is that the car seems to lose some traction... It should be good if traction is high, but the car will slide around if at the day of low traction!
Originally posted by STLNLST
Good luck but it won't happen
Does CGM kit come with all molded plastic graphite parts ? including the plastic graphite suspension arms ?
Keep the chit chat over in the schumacher thread, we only talk about setups and helping other people with their SD's. Those guys are too uptight
Originally posted by Midnight
I posted a question about two weeks ago and no one never answered.
Just took some pics of my CGM in todays shape.
Rayspeed uperdeck is there because i want to see how it behaves ultrauperstiff, Xray has stiff chassis and says that's better, well the Xrays has nothing against this CGM-setup in stiffness.
Mounted my new Alu motor mount too, the Yokomo one. Pretty nice looking
I need a better cam
I need a better cam
Hey, nice car Sparx ! I like the RS upper deck.
I wonder if I buy CGM kit and install the upper deck from SSG kit, is it possible ?
Originally posted by Nevada
Matt, I'm running mod w/foams this weekend. I'm going to try to beat the Schumacher squad. Wish me luck!!!
btw: The cgm chassis does twist and its not my tweak board.
Anybody got Billy's worlds setup yet?
If you think CGM will not get tweak, all I say is "good luck".
When I had my CGM, I CAN twist the chassis by hand holding the car at both ends with my thumbs/palms at the shock towers even easier than the double deck version. However, it didn't "hold" the tweak after hitting the boards unlike the black/ssg. Since it has no top-deck, it just "springs" back into its original shape. Again, this is just MY observation. I think this is what people mean that it does not tweak as much.
