Yokomo MR-4TC SD
Well i got mine from Steve So i am happy. The trick is to pre order very early i knew these cars were going to sell out quick, just got to wait for it to arrive now.
Originally posted by lee82gx
wow, it's all blue!
Are those springs also stock(included in the kit):
Yokomo yellow front
Yokomo blue rear
wow, it's all blue!
Yokomo yellow front
Yokomo blue rear
I wish i could afford it, it came at the wrong part of the year as i had one preordered but the pennies arn't there!!!
There's got to be somebody in Cali who got his kit today. Pix please. Even just a pic of the box.
looks like a Tamiya
pro 4 looks alot like the SD but different, SDW looks similar to a tamiya but its a yokomo!!! Manufacturers "copy" other companies designs into their own chassis.
jaybee, from what i can tell, they have the ss and sss shock bodies, with the ss being the long bodies, but only one part# for shock shafts, well two numbers, one for the standard shaft and the one you have for the gold shafts. so i guess your good to go.
So nobody got their hands on an SDW today? Pause building for a moment and post some darn pix!!
Santa came in early.
Got my SD Worlds Replica and a 415MS
HAPPY HAPPY JOY JOY!!!!
but I have to wait till Xmas to open it. I'm so stoked!
anybdoy race in ga that has a mr4? i got the ssg and thinkin bout racin it..was just gonna bs and drift it but racing looks a little more fun... anybody got a good basic setup for it?
The kit setup works fine. Try it first and go from there.
CGM for sell
has all the hop-ups you can want, hit me up on the P.M.
Got some good news for everyone, it looks like all the special aluminum peices like the bulkheads and motor mount will be available seperately, at least for the time being. Here's list of SDW specific parts, there's no pricing yet and yokomo usa doesn't know how many of each will be available yet, but they are getting some of each part.
MR-4TC SDW (SPECIFIC) PARTS LIST
PART NO. DESCRIPTION
SD-200LW SERVO SAVER MOUNT PAIR
SD-200BW SERVO SAVER POST & COLLET
SD-118GW BATTERY PLATE GRAPHITE
SD-118MW BATTERY POST PAIR
SD-300FFW ALUM. FRONT SUSPENSION MOUNT FRONT PIECE
SD-300FRW ALUM. FRONT SUSPENSION MOUNT REAR PIECE
SD-630W SPUR GEAR HUB
SD-302W ALUM. TRANSMISSION CASE
SD-644W MAIN DRIVE SHAFT HOLLOW GRAPHITE
SD-010FW FRONT UNIVERSAL DRIVESHAFT W/ SPACER (same as YMP type, but blue)
SD-010RW REAR UNIVERSAL DRIVESHAFT W/ SPACER (same as YMP type, but blue)
SD-008HW F&R LOWER SUSPENSION ARM (shorter span HD front, standard HD rear)
SD-304W MOTOR MOUNT
SD-017W FRONT SHOCK TOWER GRAPHITE
SD-018W REAR SHOCK TOWER GRAPHITE
SD-003W UPPER DECK GRAPHITE
SD-016RF REAR BODY MOUNT PLATE (FRONT) GRAPHITE
SD-016RR REAR BODY MOUNT PLATE (REAR) GRAPHITE
SD-002W MAIN CHASSIS GRAPHITE
SD-412WF FRONT ANTI-ROLL BAR SET (same as RS-25 sway bar)
SD-412WR REAR ANTI-ROLL BAR SET (same as MR-4TC upper sway bar)
SD-016HW FRONT BODY MOUNT SUPPORT GRAPHITE
NEW HARDWARE PARTS
ZC-206SA ALUM. BALL STUD HARD COATED W/ STOPPER
SD-304W MOTOR MOUNT
NEW HARDWARE PARTS
So the parts didn't come with the kits? Can't run the car yet then. Damn boards keep getting in my way.
