Yokomo MR-4TC SD
#7951
The only thing I know to fix that is get a screw from another company. I don't know the dimentions of that particular screw (3mm or what). But I did stop in my Local Hobby shop and replaced some 3mm screws from my Yok YZ10 with some from hobbico that were found in the airplane aisle. You might want to check there.
#7952
wcoyote,
thanks for the tip, i'll see what i can find at my local hardware. I'm hoping to find something that is made of a hardened material of some sort.
Also thought about trying an AE type screw and nut combo, has anyone tried this?
#7953
our LHS does not carry Hobbico products.
#7954
It's an M2.6 screw.
I have to say I have never had an issue with those screws in 2 years of Yokomo running - my tip is lots of black grease all around the thrust assembly - but it seems you're already doing that.
#7955
Darn. I thought that any shop that sells R/C would sell some R/C Planes too. I was also told that HPI usually has some 3mm screws too, if that is the right measurement. I haven't heard of anyone using the AE nut and bolt set up.
#7956
2.6 metric eh? That may be tougher to find then. But it never hurts to check replacement hardware for other kits, car or not.
#7957
I think there has been a revison of the hub carriers, they are now a lot thicker, as for the king pin issue, put a TINY TINY bit of CA or some rubber based glue and it will hold it in there good.
#7958
sosidge, wcoyote, AzNDRAGster
thanks for the tips guys, i checked it is an m2.6 screw. AzNDRAGster, as for the hub carriers, will the revised ver. have the same part no. as the old one? would like to try those out. Will try CA'ing the king pins too. thanks again.
#7959
Good question, they don't have seperate part #s for the revised one so, I would think its the same part #.
#7960
hey guys im just new in electric and i bought a ssg im just wondering wats the best set up for the car? like cambers, toe in,toe out etc.... can you guys give me some tip
thanks
thanks
#7961
Re: sosidge, wcoyote, AzNDRAGster
#7963
thanks
thanks
carpet, ashphalt, polished wood.
#7964
Anytime glide! Just let us know if you find something that works for the diff screw. I'll keep it in my reference book. That way, if anyone asks again we will have the right answer at first.
#7965
Originally posted by Jeff Werner
How has the Speedtech Spools been working out? I love the idea of having a purpose built spool...just need to get it ordered!
Jeff
Jeff
