Yokomo MR-4TC SD
#4336
Randman: yes the Tobee axles are thicker, at least the side wall anyway where the pin goes through the stub axle. Maybe I can post a picture later.
rtypec: Can you say: "TRF 415"??? (By the way, there's already a thread for that car)
#4337
R/C Tech Elite Member
#4342
stalling in corners
Matt or anyone who may know,
on carpet may car seems to stall in the corners, especially if I give too much steering input. The car seems to roll over on itself (stalls) even traction rolled once or twice.
Set up:
Front:
shock: sss, 61.5mm, gray gt4 srping, trinity 50 wt, #3, out on stock tower, stk. on arm, droop: 6mm, .8 shim under front arm mount, spacer under steering spindel, camber: stk on carrier -middle, 2nd row middle
Rear:
shock: sss, 62.5mm, gray gt4 spring, trinity 45 wt, #3, up and out on tower, 2nd from hub on arm, droop: 4.5mm, no shims/spacers, camber: stock on hub, stock on tower
58.5 mm tires (28 mm wide) tan front (37) magenta rear (35), ride hgt.: front- just under 5mm, rear- 5mm (track min. 5mm), stock arm spacing 3/1 front, 2/2 rear, gm3 104/30, front diff tighter than rear (mod setting), camber set for even tire wear, proto alfa 2.0 small wing.
track size: 93' x 43'
Eric
Set up:
Front:
Rear:
Eric
#4343
Fike, check out the latest setup on my website. www.mo-net.ws . That is what I ran last time out and it was pretty good. I have not had it try to traction roll on me once.
What I would try on your setup is:
1. Add some antisquat to the rear to free up the rear end coming into the corner.
2. Lengthen the front camber link to take away some initial steering and give more mid to exit steering.
#4345
Originally posted by Randman
Is there a carpet track up there in Sac, Mo?
see the website: http://www.stocktonrcraceway.com/
awesome track and great turnout... let me know if you come up... I'll try to make it as well.....
#4346
Mo, thanks I'll give that a try.
Eric
Eric
#4347
Originally posted by rc-zombies
It's at Stockton Co. Fairgrounds...
#4350
Hi guys
One page back people were talking about square ti input shafts where can i find some ? do they have aweb site or can i get them from Steve.
