Team Losi JRXS Type-R >
Like Tree52Likes
Old 07-17-2009, 02:02 PM
  #9871
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Right now it has huge pieces of brass screwed down to the sides towards the front. Way too much weight up high away from the center. You could say it balanced, but only physically. The center of mass is way too high.
liljohn1064 is offline
Old 07-17-2009, 02:13 PM
  #9872
Company Representative
SweepRacingUSA's Avatar
why do you have that huge brass screw on you car?
SweepRacingUSA is offline
Old 07-17-2009, 04:29 PM
  #9873
The orginal owner did it to bring it up to weight and balance it. Weird, yes. The plates are drilled and tapped and fit right over the forward countersunk holes on the chassis. Its a little extreme. I got the car late in the winter season, so I just ran it that way. It drove fine. Now I want to get it right and have some real fun with it.
Old 07-17-2009, 05:00 PM
  #9874
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Listen people. DO NOT WORRY THAT MUCH ABOUT YOUR CAR BALANCE.
I never once put my car on a scale during my 2.5 years with a losi car. I put the speedo on the left front up by the standoff, the reciever on the right with about 5 pieces of weight and the weighted tray and the rest of the weight wherever you can fit it and drive the car. I'm pretty sure I couldnt tell if the car was out of balance so I doubt it makes that much of a difference.
L.Fairtrace is offline
Old 07-17-2009, 05:12 PM
  #9875
John Tag's Avatar
Trader Rating: 42 (100%+)
My point exactally..
John Tag is offline
Old 07-17-2009, 05:16 PM
  #9876
I think you can tell the diffrence, heavier side have more spring pre load than other side, that can makes a car handle diffrent.
I am kinda guy saying "shut up and drive!" but having neutural feeling car does help me do better.
Old 07-17-2009, 08:06 PM
  #9877
I'm with you there on the balance. I only use a scale to get my other cars up to weight. I get it roughly close from side to side lifting it down the middle on my fingertips and seeing if its too tippy one way or the other and leave it go at that. I'm not trying to run 100mph, just having some fun and trying to understand the car.
Old 07-17-2009, 08:50 PM
  #9878
YmeBP's Avatar
Trader Rating: 32 (100%+)
But ..... I can't cut comms anymore, i dont have to change crystals, i don't have to mount tires, and the car doesn't go out of tune .... so if i can't balance the car 50/50 what do i do w/ all that time in the pits?
YmeBP is offline
Old 07-17-2009, 08:55 PM
  #9879
I have felt the diffs in your cars, maybe you should work on that.
Old 07-17-2009, 11:40 PM
  #9880
syndr0me's Avatar
I found a very clean roller and some parts while cleaning out my closet. Anybody looking for a second kit? Gimmie a shout, I'd rather an existing owner get it so they know what to do.
syndr0me is offline
Old 07-18-2009, 04:46 AM
  #9881
I don't know what testing some of you guys have done but I have tested f/r weight balance and it makes a difference. For years I just ran 50/50 cars but when oz went 5cell for mod I ended up with a slightly rearward balanced chassis. After a bit of bugging I tried moving the pack forward and the car was radically different. It picked up more steering everywhere and in many ways the chassis was better to drive. As a result of that I always run a minimum of 52/48 f/r and up to 55/45 f/r on tracks which lack steering. This is all experience with rubber/asphalt but I imagine the same principals apply to foam.
Anyway before you dismiss try for yourself.
Dragonfire is offline
Old 07-18-2009, 06:26 AM
  #9882
Yeti35's Avatar
You found it? You know you had it and just forgot about it.
Yeti35 is offline
Old 07-18-2009, 06:47 AM
  #9883
YmeBP's Avatar
I made those diffs that gritty on purpose to see what your diff testing skills were like you know just helping you keep your chops
YmeBP is offline
Old 07-18-2009, 07:18 PM
  #9884
Today I shaved the axles and put on the flanged nuts with the dimpled flanges, took off the odd brass weights, shifted the electronics slightly forward, filed the top deck for Team Checkpoint battery, dropped in the new layshaft and geared the car. Its rough balanced side to side. I'm waiting on the new metal lipo tray to get it up to weight. I just wanted to say, thanks for all the pointers. All I need is our tracks spec tires and practice!
Old 07-19-2009, 05:21 AM
  #9885
Pablo Diablo's Avatar
Default Dragonfire wins agian!
Congratulations to Dragonfire for winning the ACT State Modified Title. This is one of the few carpet events in OZ and its was great to see the Type R triumph on this surface.
Pablo Diablo is offline
