Team Losi JRXS Type-R
#6841
I'm on carpet with rubber tires. The problem only presents itself in "long" corners. I don't have the problem with 90's or 180's, but there are a couple decreasing radius corners with the current layout and I just cannot seem to keep the rear of the car planted. Everything I do to try and resolve the issue makes the car suffer everywhere else. I was hoping that somebody would chime in with "it's because of running light," but now I am not sure.
There are other things that can have influence on that...the general ideia is that if you have to much grip at one wheel is because you have to much weight at that wheel. With that in mind it could help. I say this because most of the times when we tink we have a loose rear in fact what we have is to much front.
#6842
This might seem like a stupid question to you guys but what is the difference between the jrx-s and the type-r except the fact that the electronics are switched what is the difference in how they drive? also would i be just as much a competitor with the jrx-s or no?
#6844
Can I use stick pack in JRXS R?
#6845
#6846
You can do! I did try to put stick pack in JRX-S R that fit, but I noticed stick's wired/plug reach servo mount (which would be diffcult with servo mount), I changed it, same notice it reach motor ( i dont want motor burn stick's wired-plug down). I decided to buy batteries side by side.
But you can do, if you had a brain genius to figure it find way. you don't. My recommend you get battery side by side or lipo battery. Or you can check another thread: Convert Stick Packs to Side-by-sides? <<Click
Good luck!
Good luck!
#6847
but would i still be competitive against other guys and would i be able to fit a lipo in the battery tray?
#6848
#6851
You can not fit the standard Lipos in the JRXS w/o serious modification. That car was made only for side by side packs. How ever I have heard that these will fit in the JRXS fine, but there may be some looseness: http://www.amainhobbies.com/product_...ducts_id/19354
#6853
is there some way i can mod it so i can get to the connectors
#6855
