Team Losi JRXS Type-R >
Like Tree52Likes
Old 03-27-2008, 05:23 PM
  #6871
Matt Howard's Avatar
Originally Posted by Spillertwo
I am a little confused with the way the droop values are stated in the setup sheets.
Droop is mentionned as for instance 1 mm above ride height while ride height is 4 mm.
Now what would you need to have for droop on your droop gauge to set this up this way ?
Is it simply 1 on the droop gauge or for instance 3 (4-1) ?
Same question for ride height 4.5 mm and droop stated as 3mm above ride height.
To measure the droop as stated here, it's how much you can lift your chassis before the tires lift off the ground. Droop set for 1mm above ride height would be you can lift the chassis 1mm before the tires lift. I then use the gauge to make sure they're even from left to right.
Matt Howard is offline
Old 03-28-2008, 02:19 AM
  #6872
mojoman's Avatar
Originally Posted by L.Fairtrace
Here it is in my car. I cant wait to try it. The software is awesome.
Is that a prototype one way? Lucky Dog!!
mojoman is offline
Old 03-28-2008, 06:02 AM
  #6873
Yeti35's Avatar
It is the proto oneway and from what they were telling me no plans to produce them.
Yeti35 is offline
Old 03-28-2008, 07:19 AM
  #6874
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i want one of those oneways...
Matt M. is offline
Old 03-28-2008, 07:26 AM
  #6875
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
That one way isnt being made becasue it doesnt improve performance at all from what I can tell. I have run both of them many times and switching one ways did absolutley nothing. Sorry to burst all your bubbles.
L.Fairtrace is offline
Old 03-28-2008, 07:51 AM
  #6876
alainchan's Avatar
anybody use A123 battery in Jrxs type-r
alainchan is offline
Old 03-28-2008, 08:04 AM
  #6877
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
maybe if you can hook it up to a trailer behind it!! . I dont think the A123 will fit the TypeR the 5000 lipo packs are a tight fit already
Marcos.J is offline
Old 03-28-2008, 08:07 AM
  #6878
Administrator
Matt M.'s Avatar
is it easyer on oneway bearings.....i have been out of the tc game for a bit, and i seem to go through the bearings......not totally their fault though....i am hitting the walls a bit
Matt M. is offline
Old 03-28-2008, 06:34 PM
  #6879
Andy Crosson's Avatar
i have broken so many one ways i lost count, i decided im done with one-ways and i put the diff in on a high traction track w/o changing setup, i did't even notice the difference.
Andy Crosson is offline
Old 03-30-2008, 01:40 AM
  #6880
blwn06's Avatar
Talking 48p
Hey guys! i got a prs spur adaptor on my jrsx type r! Can i use this to run 48pitch gears? If so is there somewhere i can get a gear chart?!
blwn06 is offline
Old 03-30-2008, 05:06 AM
  #6881
jla8874's Avatar
Trader Rating: 23 (100%+)
Gearchart.com has the JRX-S, doesn't say Type-R, but its still 1.83 ratio. Not sure about 48pitch though.
jla8874 is offline
Old 03-30-2008, 05:50 AM
  #6882
With the PRS adaptor you can run any standard spur, so yes you can run 48 pitch if you want to.
Old 03-30-2008, 11:58 AM
  #6883
Trader Rating: 80 (100%+)
I posted this earlier and got no feedback so I thought that I would try again. I am debating between the JRX-S Type R and the Corally RDX Phi. I had the following questions. I currently drive TC5.
1. Will the following lipo fit: http://www.ultralinehobbies.com/inde...=559&parent=56 ? This is a deciding factor since these are the only batteries that I have and dont want to buy new ones.
2. What is the camber mod for the front arms? Any other modifications that are done to the car to make it work better? what is the JR link opposed to the standard lnk?
3. What spare parts and tuning parts should I get?
4. I read about this short arm modification. Do I need to get seperate arms for this or do you use the existing arms? Is it necessary for carpet/asphalt rubber?
5. What servo is recommended? I have Futaba 9550 and a Futaba 9451. Should I use the heavier 9451 due to lipo weight?
6. I read that the TC5 front C-hubs will fit on the car with some dremeling. Is this correct? Do you recommend 4 deg or 6 deg? I like aluminum C-hubs and they are only available in 6 deg for the TC5.
7. Does the car use metric or standard screws and nuts?
Thanks in advance.
cpatel529 is offline
Old 03-30-2008, 12:05 PM
  #6884
rocketron's Avatar
Trader Rating: 16 (100%+)
Link did not work
Car comes with JR Link, and you can choose if needed to use the traditional style link - using 2 ball cups and the link
Check with others at you track, but maybe caster blocks, possibly arms??
Yes IF you want to run short arms you would need to purchase. No need though in general 95% use only the stock arms (long)
Your choice on this but if Lipo and you have a 9451 - use it.
Why? Because you want Alum? Alum bends too easy and this can be hard to find.
Standard
rocketron is offline
Old 03-30-2008, 12:17 PM
  #6885
Sorry about the link.. Here it is:
