Team Losi JRXS Type-R
#3376
yeah, the car is an absolute dream as far as maintenance goes. i also really like the metric axles. anyone who had an older losi sedan knows the pain of reaming out new rims to make them fit, and how much it sucks if you ream them just a little bit too much.
i think it's so nice to work on because it seems very simple, like there's really not that many parts on the car.
#3377
on the old car i never had to ream out the holes to make the axle go through the wheel, weird
Paul
Paul
#3378
There was grumbling about my 5oz. light, 13.5 car being too fast for stock, so I got the "add weight or die" ultimatum from the guys. Nobody cared when I was losing. But oh no, you have a single night of success, and suddenly you're a big, terrible cheater! :-D
Anyway, I managed to get it up to weight with the Platinum LiPo, but it was a little more difficult than the Carbon version. I lined the top of the pack with flat tungsten weights, and trimmed the foam inserts to handle the additional height. There's a spot toward the back of the battery where you can't add any height or it won't clear the rear bulkheads, which is why I couldn't put the weight down low, under the battery.
#3379
Malc,
E-mailed Horizon Hobbies UK and Spashett e-mailed me back
that they had gone out.
DMS got theirs late Wednesday.
Parts have not turned up today, hopefully early Saturday morning.
Chris
Chris
#3380
Originally Posted by Livingston
Malc,
Chris
Chris
#3381
http://nexusracing.net/product_info....e8e246a8b65bb7
#3382
Originally Posted by DOTMAN
Go to the Nexusracing.net site and check these out.
http://www.maximum-velocity.com/tungstenplates.htm
#3383
Those are nice for sure, but they're not heavy enough. I have to add 5.5oz to my Type-R with a Platinum LiPo to make weight. I'm using .5oz weights, which still means I need like, 11.
Later,
#3384
Originally Posted by Yeti35
The spool pulley will not work unless you make the inside hole as big as the inside diameter of the attached spool pad. That is how I made mine and it is fine. They old arms will work on the new car and you have to use different pivot points which is covered in the manual if you look at the page where it shows which holes to use for which arms. As far as I know there is only the 10.5 springs and that is what I used. I doubt they are coming out with new springs but you never know.
#3386
Originally Posted by CRASH
Who was complaining about you not being at legal weight? I know of at least 4 other cars that are under weight.
Later,
Later,
#3387
Same old story "I want you to do good, just not better than me".
#3388
Chris you have PM again
